Old 02-28-2015, 02:04 AM   #1
LED86
LED86's Avatar
Drives: Black 86 GTS
I have Valenti headlights installed [Photos added]
So friday was a good day! The first set of Valenti's new headlights for the 86 arrived! I know a lot of people have been asking questions since photos started circulating and I've done my best to answer with the information I could reveal. Now they are out in the open I can freely discuss and answer questions you might have.
First up, they are of great quality and build. Valenti has put heaps of effort into these headlights. They are only compatible with the factory HID models. So that means Japan 86, Australian 86 GTS, Subaru BRZ and possibly the monogram series for you guys in the states?
I have done a couple of videos and some pictures will come later. Another video will be done soon for some installation tips on transferring the leveling motor and HID ballast from the factory headlights onto the valenti headlights. Overall I'm extremely happy with these headlights!
VIDEOS
UNBOXING VIDEO
[ame="https://www.youtube.com/watch?v=UtQZR73mX1w&list=UUw9xNwZ_rxXK-syWbTXt2PA"]Valenti 86BRZ Headlight unboxing! - YouTube[/ame]
INSTALLED DEMO
[ame="https://www.youtube.com/watch?v=uTSb7KE2zA8&list=UUw9xNwZ_rxXK-syWbTXt2PA"]Valenti headlight demo - YouTube[/ame]
QUICK PREVIEW
[ame="https://www.youtube.com/watch?v=Y1LeIq9nd_k&list=UUw9xNwZ_rxXK-syWbTXt2PA"]Valenti 86BRZ Headlight quick preview - YouTube[/ame]
PHOTOS
FAQ
Q. Will these fit on FRS or Australian GT model.
A. Short answer, no. Part of the installation process is transferring the HID ballast, cable & level motor from the factory headlight onto the Valenti headlights. In theory you could wire it yourself but its not something I have attempted.
Q. Is it plug-n-play?
A. 99% yes, there is only one wire that you splice for the DRL and its basically right next to the headlight.
Q. Can you turn off the sequential/flow type indicators?
A. Yes, there is a button on the back of the headlight to turn the flow type indicator mode on/off. Easy access by just opening the hood and pushing the button.
Q. Does it come with HID bulbs, ballasts?
A. No, you use your HID bulbs and ballast and leveling motor from the factory HID headlight and transfer onto the valenti.
Q. What types are available? LHD/RHD, colors etc?
A. Only RHD versions are available (Japan/Australia etc). Color options are chrome or black, there is no smoked lens version as thats pretty much illegal anywhere.
Q. How does the DRL function?
A. You can see a stepped row of LEDs and an illuminated eyebrow. The top half of the LEDs are the DRL and are on as soon as the car starts and stay on. The indicators are the bottom half of the led and function as you would expect. The eyebrow I suppose you would call your "position light".
With the lights set to "AUTO" the brow will be off when it detects sunlight and your headlights are off, they will turn on when it detects night time and come on with your headlights. They also turn on manually if you set the stalk to ILLUMINATE, which you would normally use when its just starting to get dark and you need to illuminate the speedo.
That's pretty much all I can think off right now. Any more questions post away and ill try to answer. Keep an eye on my youtube channel for more videos.
LED86 is offline   Reply With Quote
Old 02-28-2015, 04:16 AM   #2
HueyLooie
Drives: Scion
The light almost looks blue...is that really the case?
HueyLooie is offline   Reply With Quote
Old 02-28-2015, 04:43 AM   #3
LED86
LED86's Avatar
Nah the camera didn't pick up in the color to well. It's pure white
Old 02-28-2015, 04:46 AM   #4
3ananaPie
Thank you for the video/information. Any chance you can share pictures of the DRLs and running/side lights (not headlights) during the day to show the brightness.
3ananaPie is offline   Reply With Quote
Old 03-01-2015, 07:29 AM   #5
LED86
LED86's Avatar
Yup ill have photos pretty soon. Been a busy weekend so didnt get time. They are very bright though.
Old 03-01-2015, 11:33 AM   #6
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
OMG...dat cut-off!
Thanks for posting this - great to finally see them installed after waiting for substantial information on them for over. I'm not sure if they're for me, but they do look very nice, and it's good to see a headlight option from Valenti.
Too bad I can assume we'll have about the same wait before we can see their new tail lights from this past TAS .
Ammunition is offline   Reply With Quote
Old 03-01-2015, 02:55 PM   #7
Squishy86
Squishy86's Avatar
Drives: Your Car
Is it black and blue or white and gold?
Squishy86 is offline   Reply With Quote
Old 03-02-2015, 09:15 PM   #8
LED86
LED86's Avatar
New video uploaded detailing the process of transferring the HID bulb & ballast and level motor from your stock headlights to the Valenti headlights.
[ame]http://youtu.be/xz6SOvIcNMc[/ame]
Old 03-03-2015, 08:52 PM   #9
07jazzrs5gt86
Drives: Firestorm 86
Too bad don't work with the FRS yet
Been waiting for a long time for this
Best looking aftermarket headlights so far.
Since there's a way to get the JDM headlights to work on the FRS you think the same method would work for these?
07jazzrs5gt86 is offline   Reply With Quote
Old 03-03-2015, 11:29 PM   #10
LED86
LED86's Avatar
If you could source the correct ballast, bulbs and wiring and then figured out the connector wiring yourself in theory you then could.
Old 03-03-2015, 11:41 PM   #11
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
so these are plug and play for 10series/monogram/rs1.0 ?
Old 03-04-2015, 12:03 AM   #12
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Wish I had these instead lf the spec d now.
Chen is offline   Reply With Quote
Old 03-04-2015, 09:08 AM   #13
LED86
LED86's Avatar
If those models come with the factory HID headlights then yes.
Old 03-06-2015, 01:53 PM   #14
itsibarra
itsibarra's Avatar
Drives: Supercharged Car
Been waiting a long time for these as well. I have been trying to source all the wiring diagrams/moto-diy to see how to possibly retrofit these. I don't wanna spend ~$1000 and then end up burning something out. :/
itsibarra is offline   Reply With Quote
:popcorn:, did not read
WTB: Smoked Valenti Tails. Smoked Valenti Reverse. Spec-D Headlights. Kephrii Want-To-Buy Requests 0 02-18-2015 01:42 PM
Valenti Headlights WhiteRose Scion FR-S / Toyota 86 GT86 General Forum 13 02-01-2015 03:52 PM
FS: oem headlights & 1 Valenti enthennd Exterior Parts (Aero, Lighting, Etc.) 11 11-04-2014 06:31 PM
valenti tail lights installed gsrmn Cosmetic Modification (Interior/Exterior/Lighting) 9 09-05-2014 04:54 PM
Valenti's Installed! (Picture/Video HEAVY!) 636 Cosmetic Modification (Interior/Exterior/Lighting) 28 08-22-2014 03:54 AM
