Old 02-24-2015, 05:42 PM   #1
Speedhead
Drives: BRZ DIT;VX220 T;'85 Silvia S12 FJ20
Stronger Transmission Internals, Wishlist
Hi,
I am currently investigating the topic with regards to developing stronger transmission internals. When you're able to send 520 Nm into the tranny, that question comes by itself...
Here I would like to ask the community to shed some light on the top problem spots, with regards to:
- strength/torque capability
What are the weak spots?
- what additional optimisation can be done, especially regarding forced induction applications (DIT, FA20D with turbo)
i.e. Gear ratios, shifting process (not really convinced by the shifting time/smootheness.
Together with a partner, we are currently planning to develop complete gearkits in 2versions:
A) synchronized daily driver version capable of 600 Nm
B) fully sequential racing spec gearbox with even higher torque rating
So any input is very welcome
Speedhead is offline   Reply With Quote
Old 02-24-2015, 07:15 PM   #2
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
-Jack Burton
The Following 2 Users Say Thank You to tahdizzle For This Useful Post:
cdrazic93 (02-24-2015), Jeff Lange (06-28-2016)
Old 02-24-2015, 08:19 PM   #3
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I am verrrryyyy interested in this thread...
From what I have read about this 6 spd is that its like glass.
First off, syncros are usually always a weak point.
Secondly, when the final gear is lowered there is less stress on the gearbox
thirdly, those who push the car to its limits seem to sheer 4th gear in particular.
Finally, those who have opened the manual 'box up have noted that there is tight living quarters in there for the gears, unless you have an iconel gear set i have no idea how your going to fix the stock box holding capacity.
Some describe a grinding between 1st and 2nd in cold weather. Im going to chalk that up to trans fluid as well in case you wanted to look at that.
Food for thought.
The Following User Says Thank You to cdrazic93 For This Useful Post:
Speedhead (02-25-2015)
Old 02-24-2015, 08:25 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
what if each gear had a turbo? To help with speed
Or, if the gears were made of unobtainium?
Also, you'll make far more money silencing the "crickets" that so many people are "concerned" about than a stronger tranny
(hehe)
The Following User Says Thank You to continuecrushing For This Useful Post:
cdrazic93 (02-25-2015)
Old 02-24-2015, 09:27 PM   #5
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
My built trans should be done before summer. A lot of things internally are being replaced/upgraded and geared more for big power, turbo setups. I'll be sure to test it hard with around 600whp and 26x10.5x15 Mickey Thompson radials haha
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
M1K3 (02-25-2015)
Old 02-25-2015, 02:02 PM   #6
Shit Luck
Drives: red frs
Why not just cryo the stock parts???
Shit Luck is offline   Reply With Quote
Old 02-25-2015, 02:42 PM   #7
rlpaul
Drives: point A to point C. Screw point B!
Didn't @Reaper do this? With not much success? I'm pretty sure somebody did if not him.
rlpaul is offline   Reply With Quote
Old 02-25-2015, 03:02 PM   #8
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
The problem with the trans is it's the same unit in the V6 Camaro. It's just a mass produced cheapy. It gets the job done where it needs too w/o being too expensive.
If you want a good trans get a T5WC or a Getrag, or a t56, etc. Bell housing adapters are a much more feasible means to an end then working on this slouch of a transmission.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 08-12-2015, 11:40 PM   #9
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I did. It didn't work.
Old 06-28-2016, 06:36 PM   #10
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Originally Posted by Hyper4mance2k View Post
The problem with the trans is it's the same unit in the V6 Camero. It's just a mass produced cheapy. It gets teh job done where it needs too w/o being too expensive.
I know this is an old thread, but if it was the same transmission as the Camaro it would probably be fine. The FR-S/BRZ transmission isn't related to any Camaro transmission at all, and is physically half the size of the Camaro V6 transmission.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 06-28-2016, 07:00 PM   #11
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
It's called a custom bell housing and the TREMEC T56. Vendors and developers have been talking about making something a drop in kit for years but nothing happens. Just over priced gear sets with 1 year warrantys.
We can use a hydraulic throw out bearing and ditch out shift fork that tends to break at the same time.
The supra trans is an option but the cost for the kit and used transmission isn't worth it for 80% of us.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 06-28-2016, 07:05 PM   #12
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Jeff
Quoting a months old post does nothing to better this thread, unless you think starting a fruitless argument somehow makes a contribution to the wealth of knowledge. The Rx8 and the NC Miata AZ6 transmissions look nothing alike, but they are nearly identical internally. I was told by multiple aftermarket parts manufacturers (a clutch manufacturer included) that the Aisin transmission in our car shares its architecture with the Aisin trans in the V6 Camaro. Take that for what you will...
Old 06-29-2016, 01:28 AM   #13
Jeff Lange
Jeff Lange's Avatar
Wasn't intended as an argument, just wanted the correct info out there. For future people like me that stumble across the thread looking for info.
For what it's worth the Aisin trans in the Camaro was an AY6 (also used in the CTS, IS250, Tacoma, FJ Cruiser, Mark X GRMN, etc.), which is a tailset design and has a fully-supported output shaft and an integral bellhousing. The FR-S/BRZ used the smaller AZ6, which is an older, more conventional design.
They are both made by Aisin though.
Aisin AZ6:
Aisin AY6:
Side by side (AZ6 on the left, AY6 on the right):
Jeff
The Following 3 Users Say Thank You to Jeff Lange For This Useful Post:
Hyper4mance2k (06-29-2016), Kris86 (06-30-2016), Stonehorsw (12-14-2025)
Old 06-29-2016, 01:41 AM   #14
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
My bad the Camero got the AY6. I thought it was also an AZ6.
Still AZ6 has been unable to hold up in just about everything it's been put in.
stronger/forged internals Tyson Engine, Exhaust, Transmission 24 03-15-2013 04:38 AM
2013 Wishlist BrzRacer Member's Car Journals 9 02-04-2013 08:57 AM
FR-S Wishlist build!! Opinions welcome!! Spencer Strayer Engine, Exhaust, Transmission 4 01-22-2013 05:23 PM
Scion FRS Trunk Garnish wishlist item request midnightfrolic Exterior Parts (Aero, Lighting, Etc.) 0 11-30-2012 01:59 AM
Kronos now has a Wishlist on our website! FAQ / Screenshots Inside KronosPerformance Announcements, Contests, Giveaways 1 06-18-2012 01:04 PM
