Old 02-21-2015, 06:54 AM   #1
TnRen41
TnRen41's Avatar
Drives: 14' Asphalt FR-S MT
Window tinting
Ok guys this is probably a stupid question but I know y'all can help me out. I wondering if tinting the rear window effects the defrost elements in the window or if the elements in the window can some how mess up the tint. I'm just trying to get all the facts before undertaking this task thanks for any help you can provide.
Failure is not an option.
TnRen41 is offline   Reply With Quote
Old 02-21-2015, 07:06 AM   #2
extrashaky
Drives: 2014 BRZ Limited
I've had mine on for six months with no issues. The guys who did mine said it wouldn't affect or be affected by the defrost at all. Then again, I went for the more expensive ceramic tint, so I don't know if that holds true for the cheap $150 jobs.
Old 02-21-2015, 07:11 AM   #3
Aiden
Aiden's Avatar
Drives: Firestorm Scion FR-S Monogram
I've had 20% on my back window for about 5 months and I've never noticed my defrost not working as efficiently as before or bubbles forming on the tint itself.
I would love to have input from people who've had their tint for longer than that though.
Edit: Mine isn't the ceramic tint.
Aiden is offline   Reply With Quote
Old 02-21-2015, 08:27 AM   #4
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Had my 30% tint for about two and a half years now and I haven't had any issues. Nothing fancy like ceramic and paid about $ 200 if I remember correctly.
Demandred7 is offline   Reply With Quote
Old 02-21-2015, 12:45 PM   #5
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Tinting back window has no effects on defrosting. My previous car before FRS had back window tinted for 9 yrs and no issues as well with defrosting.
I did have a issue back in the 90's with my Honda Civic Hatchback because the stupid dealer had inexperienced workers do my tints. They cut into the rear window grid, those lines on the glass. When that happens the window has to be replaced.
Have your tints done by a reputable tint shop.
Been told the silver metallic looking tints can interfere with power window switches. Get ceramic tints and call it a day.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 02-21-2015, 01:49 PM   #6
Dake
Dake's Avatar
My last car had the dealer installed tint on it for eight years with no problems. The current ride is over two now with the dealer installed tint and no issues either.
I admit, I've always been a little paranoid so I only use the rear defrost when absolutely necessary, and my cars have been garage kept most of the time so I don't need to use it frequently - but that's just me. The defrost works fine and no bubbling of the tint.
Dake is offline   Reply With Quote
Old 02-21-2015, 05:34 PM   #7
Jegan_V
Drives: 2023 Subaru BRZ
My rear window is tinted and I have zero issues with the rear defroster. Its still capable of melting snow and ice.
Jegan_V is offline   Reply With Quote
Old 02-21-2015, 09:29 PM   #8
Shinobu's Smile
Drives: 2010 Tacoma, 2015 BRZ AT Limited
I have the opposite issue. The defroster causes horizontal air gaps under my tinting which distorts the image out the back.
Shinobu's Smile is offline   Reply With Quote
Old 02-21-2015, 09:45 PM   #9
Can I install window tint on a window with defroster lines?
Yes, you can install window tint on windows with defroster lines. Infact, it may make the defroster work a little better by allowing the small amount of heat generated by the defrosters distribute throughout the window more evenly.
You may also not a little distortion where the defroster lines are. That's because the film has to bend over the lines, causing minor visual distortion that does not affect overall visibility through the window.
The only thing to be careful about when tinting windows that have defroster lines is when cleaning the window prior to installing the film. You can't use a sharp blade to scrape the windows clean. You could accidently cut through one of the defroster lines, causing that line to no longer work.
Instead, you need to use a scrubbing pad (like the kind you scrub dirty dishes with) to scrub the window. Just be sure to thoroughly wash away any debri that may be left behind from the scrubbing pad before applying the window film.
Another caution with tinting window with defroster lines comes when/if the film needs to be removed from the window. Again, you can't use a sharp blade to scrape the film away with. Instead you'll want to use a mild chemical agent to disolve the adhesive or use steam to aid in the removal of the film.
http://www.northerntint.com/faq/show...ster+lines+:12
Nu_era (02-21-2015)
Old 02-22-2015, 01:21 AM   #10
Kaily
Kaily's Avatar
Drives: 2014 Hot Pink FR-S!
Has anyone gotten limo tint in the back? I've heard it reduces visibility from the inside by a lot, but I haven't seen it for myself.
Kaily is offline   Reply With Quote
Old 02-22-2015, 01:24 AM   #11
Not on this car but had it before. Pulled it after about 2 months and went 20%. You can't see shit through it!
Kaily (02-22-2015)
Old 02-22-2015, 04:00 AM   #12
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I've had limo on my previous car, it's like nothing in the day. But at night it's pretty pitch black unless there's a lot of outside lighting.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Kaily (02-22-2015)
Old 02-22-2015, 01:26 PM   #13
86geek
86geek's Avatar
Installation wasn't done correctly or the type of tint film they used was crappy. Ceramic tint film is the bomb.
Old 02-22-2015, 02:54 PM   #14
retoocs
I have limo tint and you really can't see out the back at night. The low position of the reverse lights don't help either. Backup cam is on my list of things to install.
retoocs is offline   Reply With Quote
The Following User Says Thank You to retoocs For This Useful Post:
Kaily (02-22-2015)
Window Tinting? teek Northern California 3 11-01-2014 06:17 PM
Window Tinting NYC x1UP NY / NJ / CT / PA 24 08-28-2014 05:44 PM
Window tinting at Vancouver? voyager2285 CANADA 3 07-04-2013 08:15 PM
Window Tinting JohnAyySays Cosmetic Modification (Interior/Exterior/Lighting) 3 03-11-2013 09:50 PM
Midnight Window Tinting shiud Northwest 2 01-24-2013 03:34 PM
