Old 02-19-2015, 02:44 PM   #1
juliog
juliog's Avatar
Drives: 86
Quiet-est single exit?
Other than the first 30 seconds after a cold start, my current setup is extremely quiet. There's no drone on the freeway and cruising under 80, it's virtually inaudible and road noise takes over (them RS3s...):
PTuning 4-2-1 EL header (catless)
Tomei overpipe
Tome straight pipe (hatless)
OEM catback
I no longer drive this car on a daily basis, so I'd like to save weight by ditching the OEM catback. Single exit exhausts would provide the most savings, but I'm concerned about sound levels. It seems like most single exits are obnoxiously loud (Tomei would be out of the question). Among the dual exit options, the TRD USA and Q300 are not much louder than stock, but for a saving 5-6 pounds I wouldn't bother.
Any suggestions? I'd be getting a Driveways labs diffuser at the same time so I'm not concerned about the gap between the rear axle and the rear bumper.
juliog is offline   Reply With Quote
Old 02-19-2015, 02:49 PM   #2
Koa
FT86SF V2 is loud. Here's my OFH + FT86SFV2 single exit non res cbe.. stock FP/OP
[ame]http://youtu.be/rHKRIegPyd8[/ame]
Old 02-19-2015, 02:57 PM   #3
swarb
It's really a compromise between loud and weight. Any round can is going to be loud, so you would want a oval can, which is heavier. Then there are inline resonators and helmholtz resonators also.
I would personally go with the largest oval can I could find, since you don't have any cats.
Old 02-19-2015, 10:50 PM   #4
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
I recently picked up a lightly used Tanabe Concept G single exit. I might get to install it this weekend and will let you know how it sounds if so. It comes in under $600 from FT86SF new. I got mine used for significantly less than that so if it is too loud I can resell it without taking a big $$ hit. It seems there isn't a ton of info out there on the single exits, but this might be one of the quietest available. My apartment complex hopes it is anyway!
Briankbot is offline   Reply With Quote
Old 02-19-2015, 11:25 PM   #5
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
Great for daily driving ! louder than stock but quiet enough to stay legal
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 02-20-2015, 01:53 AM   #6
2much
I wanna go fast
Drives: 2013 FR-S 6MT
I am in the same boat, looking at quieter single exit systems. best one I think I've seen so far is the TF works with dual resonators.
2much is offline   Reply With Quote
Old 02-20-2015, 02:10 AM   #7
akahenry
akahenry's Avatar
Drives: '18 STi
pls post a review and tag me in it of how you like the exhaust after you've installed it!
akahenry is offline   Reply With Quote
Old 02-20-2015, 03:18 AM   #8
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Ask JDL for a custom titanium header back or cat back.
Old 02-22-2015, 08:38 PM   #9
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
Installed the Tanabe Concept G today. I will do a full review once I get to drive it more. There is a crap ton of snow on the ground right now.
My initial impression is that this exhaust is damn quiet. Other than cold start, it is barely louder than stock in my opinion and has a nice tone. Throttle response seems improved, but that could just be my tires spinning in the snow
Old 02-23-2015, 10:59 AM   #10
SCharged
Drives: asphalt fr-s
Other mods?
SCharged is offline   Reply With Quote
Old 02-23-2015, 11:49 AM   #11
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
Originally Posted by SCharged View Post
Other mods?
I have no other mods which would affect the exhaust sound.
Old 02-25-2015, 04:36 PM   #12
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
I HAD the tanabe concept g paired with motiv catted fp and op, and sounded like an s2000 with exhaust just to compare. low rpms is where is sounds louder than stock but quiets down at higher rpms. Its lovely IMO
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 02-25-2015, 04:51 PM   #13
mad_sb
Drives: 2013 Asphalt FR-S
you basically have 2 options to maintain a decent volume and no rasp:
Catless header and front pipe with stock catback or Q300
Or
Stock header with any catback you want
Every other combination I have tried myself or heard gets loud and raspy very quick. With your current setup, going to any single exit will be loud and likely raspy. Even running a catted aftermarket header and catted namless front pipe was loud and a bit raspy on my custom single exit (varex muffler). That setup sounded mean as hell with the varex fully open, but way too loud for a daily driver, would have been perfect for a track day car though.
My advice would be to pick the single exit with the largest can and a resonated midpipe. It may still be too raspy though.. these things are rasp monsters when you remove the cats and don't run a suitcase muffler.
Did I mention rasp already lol.
Old 02-25-2015, 07:57 PM   #14
akahenry
akahenry's Avatar
Drives: '18 STi
Perhaps go custom and buy a Greddy RS Universal Muffler or some sort of universal single canister muffler and either modify the OEM mid pipe (adding a bigger resonator) or get a custom mid pipe to fit the muffler. Adding a bigger resonator, however, will probably limit the amount of weight you originally wanted to save, but I think it'll be worth it--for the sake of your neighbors and people around you. Honestly, this is a hit or miss type of thing--to save weight for more gains or to sacrifice some power for civility. On a side note, I dare you to add the Tomei Type 80 to your set up hehehehehe
SINGLE EXIT EXHAUST karma003 Engine, Exhaust, Transmission 163 06-28-2018 02:48 PM
**NEW HKS HI-POWER TI-TIP SINGLE EXIT** genometuning Engine, Exhaust, Bolt-Ons 18 01-06-2015 09:14 PM
HKS Single exit Backfiring Mattybro410 Engine, Exhaust, Transmission 9 12-02-2014 07:36 AM
Single Exit Catback Mattybro410 Engine, Exhaust, Transmission 3 10-31-2014 12:50 PM
(WTB) single exit exhaust Kilos6 Engine, Exhaust, Bolt-Ons 5 10-24-2014 09:38 PM
