Old 02-14-2015, 08:40 PM   #1
SPCorBUST
SPCorBUST's Avatar
installed coilovers, need advice on end links
I just installed the Buddy Club Racing Spec coilovers, and the car is sitting pretty low. I'm hearing pops now, which I'm attributing to (could be wrong) the sounds of end links hitting the control arms. From my reading, it seems like shorter end links would solve this. I planned to do this anyway, but would like to make sure this is actually going to address the issue.
That being said, I'm considering the Whiteline end links, but apparently you need a generic set, not the standard BRZ/FR-S off-the-shelf variety, so that the end links don't actually touch. While that seems to be one route, I'm curious about other solutions. Also, I'm not sure whether I need to replace the fronts as well as the rears.
Any advice?
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 02-14-2015, 09:49 PM   #2
Can you get a picture of where your car is sitting and a shot through the wheel showing the endlink/swaybar position?
Old 02-15-2015, 01:33 AM   #3
SPCorBUST
SPCorBUST's Avatar
Yep, I'm seeing this just now so I'll grab it in the morning.
ST coilovers installed yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 10-08-2014 01:22 PM
ST coilovers installed ThatManAnt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 07-23-2014 08:55 PM
Fortune auto coilovers+ end links 256brz2013 Brakes, Suspension, Chassis 1 07-27-2013 05:41 PM
people that installed bucket seats..advice pls ft86me Cosmetic Modification (Interior/Exterior/Lighting) 0 06-16-2013 08:24 PM
Stance super sport coilovers with front sway bar end links 900.00 kimchangil424 Brakes, Suspension, Chassis 4 02-06-2013 02:25 AM
