Old 02-10-2015, 10:54 PM   #1
Struckbylitenin
Struckbylitenin's Avatar
Drives: 10 Series FR-S
Lightbulb 3 Different LED Fog Lamps
Different, yet the same.
What makes one better than the other two?
So far, anyone that has gotten any of the three, "swears by their choice."
I almost considered making this a poll, but I'd rather hear information regarding materials/build quality and previous experiences with the brands, rather than just "I got them, I love them."
http://www.theretrofitsource.com/led...l#.VNrPefnF98E
http://www.diodedynamics.com/store/c.../#!prettyPhoto
http://www.ft86speedfactory.com/olm-...ings-1731.html
And all the exact same price.
Maybe the vendors will chime in
Struckbylitenin is offline   Reply With Quote
Old 02-10-2015, 11:46 PM   #2
brzbrad
[||•]=(86)=[•||]
brzbrad's Avatar
Drives: 2014 BRZ Limited WRB
I've had the OLM Fog Lamps for about 3 months now. Installation was easy and I haven't had any problems with them so far. The build quality seems very good, and they are much brighter than the stock BRZ fogs, which did pretty much nothing. They have brackets that are slightly adjustable so you can find a good angle, (I'm not sure if the other ones have this too...). The bulb color is just slightly whiter than the stock BRZ xenon bulbs. Hope this helps!
brzbrad is offline   Reply With Quote
Old 02-11-2015, 10:50 AM   #3
iris mm
iris mm's Avatar
Drives: 86.R6
I currently have the xb led fog from TRS and all I have to say is performance is amazing. It matches my 5k led strip along with my hid. Fog lamp is fairly wide and has an adjustable knob.
iris mm is offline   Reply With Quote
Old 02-11-2015, 11:24 AM   #4
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
The ESUSE and Morimoto LED's look exactly the same except for the branding on the inner housing. May even be the same company marketing under different brands.
The unbranded OML fogs however, do not have an adjustment screw like the first two. Looks like adjustment is done via the two screws on the side, which can come loose. I'd opt for one of the first two just because of that.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 03-16-2015, 02:38 PM   #5
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Just installed the esuse fogs
Rican_D is offline   Reply With Quote
Old 03-16-2015, 02:59 PM   #6
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
The ones from DiodeDynamics, I believe are the same housing as the Morimoto xBs. I'm running them and absolutely love them.
malave7567 is offline   Reply With Quote
The Following User Says Thank You to malave7567 For This Useful Post:
Diode Dynamics (03-17-2015)
Old 03-16-2015, 04:19 PM   #7
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
I had a similar conversation here:
http://www.ft86club.com/forums/showthread.php?t=80272
I ended up with the Morimotos, because I could find the most information about the Morimotos. I'm sure the others are similar.
The Morimotos are will built, easy install and have a great beam. They are adjustable too. Took me about 20-30 mins to do the complete install including aiming.
Just make sure they are genuine. There's a lot of crappy replicas out there.
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Old 03-17-2015, 10:13 AM   #8
Diode Dynamics
Diode Dynamics's Avatar
Our Luxeon LED fog lamps are manufactured by Esuse, and utilize genuine Phillips Luxeon LED's.
There are plenty of knock-offs out there like a member suggested.
Nick C.
John C.
Diode Dynamics
Old 03-17-2015, 11:14 AM   #9
kbye
kbye's Avatar
Drives: 2014 FR-S
Nick C.
Is it plug and play? I ask because the pictures do not show H11 connectors, just the pins.
kbye is offline   Reply With Quote
Old 03-17-2015, 11:28 AM   #10
malave7567
malave7567's Avatar
When I bought them from Diode Dynamics, they sent the correct connectors with the lamps for H11. It was plug and play.
kbye (03-17-2015)
Old 03-17-2015, 11:31 AM   #11
iLaw
iLaw's Avatar
The Morimotos require a PSX to H11 adaptor to fit on a BRZ/FRS. These adaptors are available from Diode Dynamics for about $20
iLaw
The Following User Says Thank You to iLaw For This Useful Post:
kbye (03-17-2015)
Old 03-18-2015, 03:11 AM   #12
iris mm
iris mm's Avatar
Drives: 86.R6
The xB led fogs (Type S) doesn't require any adaptor for the FRS.
Old 03-18-2015, 12:04 PM   #13
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
We see a lot of the @Diode Dynamics led fog lights at my work, and they are shockingly bright for a fog light.
This shows the stock fogs on a fiesta ST compared to the Diode Dynamics fog lights with the same exposure etc. Only difference you see in the photos is how much better the Diode ones are. Also, you can't quite tell in this image, but the cutoff is pretty darn good as well.
Oh, and they have a 3 year warranty...so thats pretty nice
The Following User Says Thank You to continuecrushing For This Useful Post:
Diode Dynamics (03-18-2015)
Old 03-18-2015, 10:21 PM   #14
soundman98
ProCrastinationConsultant
soundman98's Avatar
all 3 of those are manufactured by esuse, so it really comes down to your own brand preference. they all use the same optics/led's.
outside of that, i believe there are only 2 brands that i'm aware of-- either rostra or esuse-- those 2 companies use slightly different optic designs, though i'm not sure what led's the rostra design uses.
the rostra's are nearly impossible to get a hold of-- this is the group buy that i heard of them from, i never did buy any though..
http://www.focusst.org/forum/group-b...group-buy.html
there is a 3rd option, but it's not highly desirable anymore with all these easy bolt-in options-- trs is still selling bmw x5 led fogs, and you could mod them to fit the car, but it requires a lot of work for slightly less width, and very little difference in output, and have an sae-compliant 5600k output color temp..
Rocket Bunny rear diffuser - Reversing lamps and rear fog lamps pr0xy Scion FR-S / Toyota 86 GT86 General Forum 3 01-06-2015 06:08 PM
Painting the head lamps Tamoor Cosmetic Modification (Interior/Exterior/Lighting) 4 01-09-2014 01:52 AM
WTB: stock tail lamps *KID* Australia Classifieds 0 10-18-2013 03:21 PM
FS: Subaru/FRS Fog Lamps ecko04 Exterior Parts (Aero, Lighting, Etc.) 5 05-13-2013 07:17 PM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 01:04 PM
