| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
Drives: '06 AM V8V Coupe
MR2 died, replacement?
Yesterday I was going along the highway and suddenly I hear a clunk, the car shakes and loses power, so I put it in neutral and managed to roll all the way to an exit ramp. OBDII scanner said cylinder 2 misfire, judging by the crazy shaking I think I lost connecting rod in cylinder 2 :/
It's not like the 1ZZ is worth much money but paying to get another 1ZZ installed is kind of dumb IMO and I don't want to drop the money on a 2ZZ swap at the moment... Replacement car suggestions? I kind of like SW20s but the fact that they're 25 years old kind of worries me. Budget not totally set (still haven't sorted out what to do after graduation) but I don't think I want to drop new FRS money for example. |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Honda Civic lx. From my experience, they make the perfect cheap beaters and they never die lol. Sw20 will be near impossible to find one that hasn't been played in. Or an Integra would be another good beater.
I'd stick to something cheap and reliable till you're able to drop a 2zz in your mr-s.
#3 | |
Part of me wants to do the 2ZZ swap but part of me is saying the platform is just too old to be investing money in at this point and I'd rather wait it out for a newer RMR car to hit the market. I just saw an SW20 ad which mentioned a timing belt change and a valve adjustment. Not dealing with that s***. Timing chain is a must. |
Drives: 1995 Supra TT & 2013 FRS
Looking to sell the MR-S shell?
#6 | |
Emperor JDM
For real though, I'd just stick to a bland reliable beater that does going from point a-b easily. I'd check out the Rsx-s if you "must have" performance. It's probably the only newer type of performance oriented car I would go for without having to go to the 1990's in the sub $5k range.
I would borrow a car a long as possible and save up for something that you won't have to work on all the time(unless you like that). Concentrate on finishing school and getting a good job, and you can have ANY car you want.
#8 | |
Member of the year - 2016
Drives: Scion FRS
One of these.
#10 |
Kuruma Otaku
This is a sign from above to do the 2ZZ.
Edit: or 2GR.
Because titanium. |
#11 |
I would do it, except I want to do a bit of upgrading to the motor if I'm putting another one in, and I think that would be a terrible financial decision. I decided I absolutely need the C60, Fidanza flywheel, shaved head for higher compression and an upgraded oil pan if I put a 2ZZ in. The wishlist includes cam regrind, Apexi PFC, electric water pump, oil-water heat exchanger, and an Accusump.
The other thing I was considering was a modified 2ZR-FE. It would be a little more powerful than the 1ZZ, but have way better response in the low end (the single VVTi on the 1ZZ lags like crazy below 2200rpm), improved torque curve, and you can probably coax 170hp out of it much easier than you can a 1ZZ. It apparently fits the same transmission but needs a custom mount, which is not a big deal. I realized the 2ZZ is on paper as good as a K20 but in reality they're a lot less reliable and you really only want to run them to 8000rpm. A 2ZR can probably take 7500 just fine, and being a newer design in my mind is more important than the last little bit. |
#12 |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
The 2ZZ is a great option for many Spyder owners but not so good in CA because of the emission restrictions. The same goes for the 2GR swap which cost about 3 times what the 2ZZ swap would cost. I have driven one of those though and they are probably worth it.
If you are not crazy about convertibles but like a similar feel when you drive then you only have one choice IMO. You need to grab a used FR-S. I have seen a few selling for under $17K already and they are not salvage titles or extremely high mileage. If you do not really need a car right now then save up for when you really do need or WANT one.
So many modders have more cents than sense!
#13 | |
I'm slightly obsessed with having the engine behind my head. FR is okay, I've been in Miatas and a Z3M and stuff but it's just not the same. I like the FRS but not enough to drop 17k. Maybe when they're down to like 10, it's definitely not the kind of car I'd want to keep for a long time. I'm hesitant on the 2ZZ because it's an old engine and this is an old car. The auto industry has really made a lot of progress; the new Honda engines are amazing, the new Mazda engines are amazing, and the next crop of Toyota engines sound really promising too. Even the GR, ZR, AR, and NR are a huge improvement over the ZZ, MZ, AZ and NZ engines. Way better torque and efficiency. If I do an engine swap I'd want to keep the car for a long time and I would prefer to have a newer engine design in there. |
#14 |
Drives: Some rust bucket
Integra GSR? WRX? Will be hard to find a decent WRX with less than 150k miles for less than 10k though.
| Car Died in front of Work | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 45 | 01-30-2018 06:48 AM |
| Car died/semi-revived need help | InvalidJohnny5 | Issues | Warranty | Recalls / TSB | 13 | 12-16-2014 03:08 AM |
| Died out at light | Legacy | Issues | Warranty | Recalls / TSB | 12 | 05-29-2013 12:27 AM |
| I just died inside. | DIG1992 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 62 | 07-02-2012 08:51 PM |
| My DD died today any suggestions? | LeavingNormal | Other Vehicles & General Automotive Discussions | 14 | 05-27-2012 09:18 PM |
