Old 02-08-2015, 03:11 PM   #1
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Time required to burn oil after error?
Wasn't paying attention and allowed a small kink in my turbo drain. Had the car ideling for about 20min while burping the coolant system. I then noticed the smoke out the tailpipe and shut her off. Made up a new drain line and reclocked the turbo and all seems to be running happily but, still burning oil out the exhaust tailpipe and wastegate when it dumps.
Since the fix I've driven the car about 5 times for 10min light sessions to clear out the oil staying out of boost. Still smoking? I'm wondering if I should just hop on the highway and flog it for an hour or so? I pulled the turbo and the up pipe looks good but, the down pipe has oil in it. Cleaned what I could with a rag but still smoking especially when I hit 210* oil temp.
Thoughts?
Old 02-08-2015, 06:16 PM   #2
ls1ac
ls1ac's Avatar
we had a similar problem with one of our turbos and after finding nothing further wrong, we were still blowing blue smoke even after we thought we had cleaned everything. it continued until we ran at speed for some time. very little oil will make a lot of smoke. ten minutes on the freeway on and off the throttle cleared the problem.
The Following User Says Thank You to ls1ac For This Useful Post:
Kiske (02-08-2015)
Heaviest Shift Knob that won't burn / freeze your hand? bren5279 Cosmetic Modification (Interior/Exterior/Lighting) 13 09-28-2014 09:18 PM
Stock Tires or Pilot Super Sport? Which to burn up? EAGLE5 Tracking / Autocross / HPDE / Drifting 25 03-20-2014 08:52 PM
If you have $500 to burn, what parts would you get? retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 73 08-08-2013 02:32 PM
curb burn on gunmetal wheels three3y3wrbbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-28-2013 03:07 AM
