Old 02-08-2015, 11:44 AM   #1
iamdaspoon
iamdaspoon's Avatar
Drives: 2015 Subaru WRX
BRZ Glove Box Lock
As you guys probably already know the BRZ/FRS/GT86 doesn't come with a lock on the glove box, has anyone figured anyway to either have one installed or get an entire replacement if they're available? I tried searching but to no avail, I'm sure I'm not the first person to think about this. Any Ideas?
iamdaspoon is offline   Reply With Quote
Old 02-08-2015, 01:56 PM   #2
swarb
mailbox lock, a drill, and a rubber gromit . good luck.
Old 02-08-2015, 02:11 PM   #3
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
just screw one of these badboys on...
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 02-08-2015, 09:09 PM   #4
iamdaspoon
iamdaspoon's Avatar
I figured those were the responses I was going to get
Old 02-08-2015, 10:06 PM   #5
Poodles
Drives: 2015 Series.Blue
Why do you need a locked glove box? Anyone that gets in the car can easily open it. The truck is the locked part of the vehicle (hit the button in the truck and it will require the key to get in). Of course that's also easily defeated, but nothing is a perfect protector...
Old 02-08-2015, 10:38 PM   #6
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
TBH most locks that we use anywhere can be opened easily. Its really just a deterrent for the types who like to snoop around your crap. Its also good for annoying children/teens/passengers.
But unfortunately, I don't have any ideas :|
PandaSPUR is offline   Reply With Quote
Old 02-08-2015, 11:17 PM   #7
swarb
What is wrong with my suggestion? If you do it clean, it will work. There is no oem option. And my suggestion probably the only solution. You want a lock. Add a lock. Or search google for glove box lock and get one of those plastic ones.
Old 02-09-2015, 11:23 AM   #8
Turbowned
Turbowned's Avatar
I recommend keeping a small lock box in the trunk if you really need to keep your valuables secure.
Old 02-09-2015, 11:51 AM   #9
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
How about just not keeping valuables in the car?
If OP is concerned about something like... police searches (they usually can't go into locked compartments), then the lock box int he trunk would work, but likely a locked box inside glove compartment would work too (although the trunk is better).
Else, you're probably looking at fabricating something.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 02-09-2015, 11:55 AM   #10
extrashaky
Drives: 2014 BRZ Limited
Swarb has it right. The thing to do would be to pick up a spare glove box off eBay, open it up to see how it works and install a small lock cylinder with an arm that prevents the little glove box handle from moving. You might be able to find someone locally who does car interiors who can do it for you.
Trunk. Not truck.
Old 02-09-2015, 01:21 PM   #11
Poodles
Originally Posted by extrashaky View Post
Trunk. Not truck.
GD phone autocorrect...
Old 02-09-2015, 04:25 PM   #12
iamdaspoon
iamdaspoon's Avatar
Didn't mean it sarcastically, I'm just not really knowledgable enough to fabricate something like that.
Old 02-09-2015, 04:26 PM   #13
iamdaspoon
iamdaspoon's Avatar
Thats what I've been doing, it is not really a theft deterrent, more of a police search avoidance. I wanted the glove box to lock though because I like having my things in arms reach as opposed to being in the trunk.
Old 02-09-2015, 05:47 PM   #14
swarb
Get a combination/key lock box. Friend uses it and it has saved his ass a few times.
brz, glove box, lock, replacement
CG Lock Seat Belt Lock Biggins Interior Parts (Incl. Lighting) 0 02-03-2014 08:41 AM
glove box 12v light? lbroskee Cosmetic Modification (Interior/Exterior/Lighting) 3 03-11-2013 10:44 PM
Loose Glove Box Spd229 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-06-2012 01:53 PM
Scratched Glove Box! greenguy101 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-29-2012 06:24 PM
Canadian BRZs with USB+3.5mm in glove box rawbz CANADA 12 07-11-2012 03:51 PM
