Old 02-06-2015, 10:56 PM   #1
Basket Case
Drives: 2013 Raven fr-s
disabling TPMS?
Is t possible to disable the TPMS sensor light completely? I don't particularly care for it working or otherwise, and it wold make m life easier next week when I have tires installed on my new wheels. ]]Can i turn it off with something like an open flash tuner or ECUtek?
Basket Case is offline   Reply With Quote
Old 02-06-2015, 11:57 PM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
why don't you just transfer over the TPMS?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 02-07-2015, 09:50 AM   #3
Donbrz
Drives: 2015 Brz Blue Series
Transfer seems more complex, or just haven't found right solution. Just traded out wheels and tires (2nd set) with new TPMS. Firestone could not get tPMS to program, and concluded that suburu dealer must do programming which I find difficult to believe. Is this accurate from experience?
Donbrz is offline   Reply With Quote
Old 02-07-2015, 10:14 AM   #4
aznatama
aznatama's Avatar
Tpms are really easy to swap and can be done without tire removal. Dealer needs to program, takes a few min.
'14 BRZ LTD MT DGM
Old 02-07-2015, 10:43 AM   #5
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
http://www.clublexus.com/forums/is-s...pipe-bomb.html
slicktop is offline   Reply With Quote
Old 02-07-2015, 11:01 AM   #6
tobin
tobin's Avatar
Drives: '13 BRZ
If you already have two sets of sensors, you just need one of these:
[ame="http://www.amazon.com/ATEQ-QuickSet-TPMS-Reset-Tool/dp/B008SCWXN4/ref=sr_1_1?s=automotive&ie=UTF8&qid=1423324780&sr= 1-1&keywords=ateq+quickset"]ATEQ Quickset[/ame]
It will read the sensor codes that come on the stock wheels, and then you need to program the sensor codes form the second set of wheels (Firestone should be able to give you these codes, they have a tool that can read them). When you swap wheels, you just plug in the Quickset and tell your car what set of sensors to read.
tobin is offline   Reply With Quote
Old 02-24-2015, 07:31 PM   #7
Uplink
Uplink's Avatar
Drives: anything you let me
Originally Posted by slicktop View Post
[ame]http://youtu.be/z8rYotiiFP8[/ame]
There was entirely too much lead-up in that post before I realized what it was actually for.
Uplink is offline   Reply With Quote
Starting car afte winter / disabling fuel injection df.dima Scion FR-S / Toyota 86 GT86 General Forum 21 11-23-2014 12:54 PM
Cruise control disabling JamesBond000 Electronics | Audio | NAV | Infotainment 7 07-02-2014 08:57 PM
traction control disabling through software? puma Software Tuning 16 04-26-2014 10:48 AM
Disabling Compass & Auto Dim on Homelink ZC6BRZ Electronics | Audio | NAV | Infotainment 2 04-20-2014 02:34 PM
Help request - disabling speed sensor on FR-S base 2014 H/U mid_life_crisis Electronics | Audio | NAV | Infotainment 3 01-27-2014 10:51 PM
