Old 02-06-2015, 03:48 PM   #1
SurfAndSand
8SiX
Drives: FRS 10series
Will Invidia Q300 muffler connect to TRD exhaust piping?
hey all
I've been looking for a way to quiet my car down even more. I've been looking at pics of the Q300 and the TRD exhaust, and it looks like the Q300 axle-back portion (muffler only) might line up with the TRD mid-pipe.
The smaller mid-pipe plus the larger muffler would probably yield the quietest results...if they line up. Can anyone confirm that the Q300 muffler would match up to the TRD mid-pipe?
Thanks!
SurfAndSand is offline   Reply With Quote
Old 02-06-2015, 03:57 PM   #2
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Originally Posted by SurfAndSand View Post
hey all
Thanks!
No it will not. They have different connections at the muffler. You will need the midpipe and small S pipe to use it. It will line up, but finding a way to seal it properly will be your challenge.
2016 Camaro SS is offline   Reply With Quote
The Following User Says Thank You to 2016 Camaro SS For This Useful Post:
SurfAndSand (02-06-2015)
Old 02-06-2015, 04:31 PM   #3
SurfAndSand
8SiX
@2016 Camaro SS
Thanks! It sounds like you've seen both exhausts. Have you heard both exhausts? Can you tell me which is quieter in cabin under light load? or in any situation for that matter, which is the quieter of the two CBEs?
Thanks again
Old 02-06-2015, 05:01 PM   #4
2016 Camaro SS
Drives: Fast
@2016 Camaro SS
Thanks again
Q300 is the quietest system for this car hands down. I went with a Perrin resonated 2.5" to get a little volume back and UEL rumble in the cabin but 0 drone. That's the best part.
You won't hear much at all light cruising on the Q300.
Old 02-06-2015, 05:28 PM   #5
btoast
Just my $0.02 as I have neither the Q300 or TRD, but much of the cabin drone is resonance or vibration that is passed through the trunk and into the cabin. The trunk has basically no sound dampening material and sounds very thin and tin-like when tapped on. I added 80mil sound deadening material to the entirety of my trunk area and it made a noticeable difference is exhaust cabin drone under acceleration. I still would like to do the rear seat area to increase its effectiveness, but as it stands it is a great sub $60 modification (less considering I still have enough mat to due the rear seats).
I am currently on a UEL with Zeta exhaust. The exhaust note is almost non-existent during cruising, but vibrates/resonates fairly deeply (at least to me) between 1000-2500RPM at acceleration.
btoast is offline   Reply With Quote
Old 02-06-2015, 06:21 PM   #6
SurfAndSand
8SiX
k...wait, so you have heard both, right?
Now, you have a resonated Perrin because you wanted 0 drone. Does that mean the Q300 had drone?
Just looking for clarity, because the Internet.
Old 02-06-2015, 08:42 PM   #7
2016 Camaro SS
Drives: Fast
No, the Q300 had absolutely 0 drone. I just could barely hear my exhaust unless I really stepped on it. Almost sounded stock inside driving normal because it was so quiet. The Q300 muffler is much larger than the Perrin, but the Perrin has a larger and longer resonator with a smaller muffler.
Old 02-06-2015, 09:00 PM   #8
SurfAndSand
8SiX
ok. So you haven't heard or driven with a TRD exhaust then. Correct?
People say the TRD is about the same as the Q300. I have a TRD, I think there's a slight "drone" with a slight load, or on engine braking. If they are about the same, then the Q300 will probably just be as loud, and I might as well not get one to save money.
Old 02-07-2015, 06:09 AM   #9
Simplicity
Simplicity's Avatar
Drives: 15' MT FRS
The TRD does have drones at around 3k RPMs
Simplicity is offline   Reply With Quote
Old 02-07-2015, 06:23 AM   #10
2016 Camaro SS
Drives: Fast
The TRD is louder because the muffler is smaller. I can assure you the Q300 has no drone. I ran it with a catless header and catted front pipe and it was always quiet inside.
Old 02-07-2015, 06:42 AM   #11
SurfAndSand
8SiX
Correct. That's about where mine drones ever so slightly
But the q300 does not?
Old 02-07-2015, 07:18 AM   #12
2016 Camaro SS
Drives: Fast
No, it does not, and hopefully other Q300 owners will chime in here and attest to it as well.
Old 02-07-2015, 08:37 AM   #13
Drewfellas
Drives: '15 frs Halo. must scrape
It's quiet as hell...... Sounds better than stock and better with Manual transmission. Don't worry cops ignore me when I'm driving around or near them. As for drone.....nope
Invidia q300-cusco front strut tower with mbc and rear strut tower- buddy club tail lights
Drewfellas is offline   Reply With Quote
Old 02-07-2015, 06:25 PM   #14
SurfAndSand
8SiX
Thanks folks. Looks like I might use $700 of my tax dollars. Some jerk dented my pass door though so I might have to pay for paint less dr instead.
q300, quiet exhaust, trd
**INVIDIA** >>SUPER SALE THREAD<< - Invidia N1 - Invidia Q300 - Invidia Front Pipes - FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 629 12-11-2016 09:21 PM
Exhaust swap - Invidia Q300 BRZ-ed Canada Classifieds 9 08-15-2014 07:49 PM
FS: Invidia Q300 catback exhaust $450 N_A Engine, Exhaust, Bolt-Ons 19 03-26-2014 02:08 PM
FS: Invidia Q300 catback exhaust N_A Southwest 17 03-18-2014 11:02 PM
WTB: invidia q300 exhaust frs/brz Pintobeangt86 Want-To-Buy Requests 0 03-03-2014 11:53 AM
