Old 06-08-2012, 02:29 PM   #1
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
FRS AT Dyno and MT Dyno
Someone did back to back pulls with the AT and the MT
Notice the different tunes.
https://www.facebook.com/photo.php?f...type=1&theater
comments are Solid line automatic, dotted manual, both stock, same dyno, 20 min apart
Auto runs richer up top, manual runs leaner also pulls more timing in the last 1000 rpms
Any idea on the tunes being different?
feldy is offline   Reply With Quote
Old 06-08-2012, 03:27 PM   #2
Tbomb 25
Balance over power...
Drives: 13 Hot Lava Frs, 88 Supra Turbo
Wow not impressive at all....the manual is much more impressive the long gearing is part of the cause for this no wonder the auto did horrible against the Renault...
Tbomb 25 is offline   Reply With Quote
Old 06-08-2012, 03:33 PM   #3
ahausheer
Re-member
Drives: Toyota camry
I thought the locking torque converter should not allow such differences, its as if the torque convert disengaged or slipped? I wonder if the difference is simply due to different engines?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-08-2012, 03:34 PM   #4
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
The auto has slightly better torque but loses 10 whp up top? I don't care really for high end power but I am happy the powerband is nearly identical before 5400 rpms. I'll never go that high most of the times anyway.
Also if the auto is running richer up top then a CAI would be better suited to lean it out a bit right?
SUB-FT86 is offline   Reply With Quote
Old 06-08-2012, 04:05 PM   #5
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
That was Feedbag's BRZ MT and CarbonBlue's FR-S AT done at Cobb Thursday night.
Feedbag's Build thread has some of that info and pics of the event.
5hairpins is offline   Reply With Quote
Old 06-10-2012, 02:06 PM   #6
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
actually when i redline shift in my auto i can feel the top end loss, so its not just the gearing its also the tune
there really isnt much of a difference, just up top and its all in the tune, tq convert is locked from 1500 rpms to redline, never disengages
that's still up in the air as well... dont want to trick your ecu with an intake but genuinely give it more air, tricking the engine will kill it like most CAI do
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 06-10-2012, 02:21 PM   #7
serialk11r
Drives: '06 AM V8V Coupe
Closed loop operation :O Tricking the engine will make it figure out that you tricked it and add more fuel.
Old 06-10-2012, 03:30 PM   #8
Turbowned
Turbowned's Avatar
Wow, the AT really seems to fall on it's face after ~6200rpm! That's kinda lame.
Old 06-10-2012, 06:00 PM   #9
SUB-FT86
86 Member
This would explain why the 1/4 miles between the MT and AT have been about 1.1 seconds I bet(14.8 vs 15.9). The gearing even though slightly better should've been it a .3 seconds difference but with the engine making less up top this car with a automatic is essentially a mid range horsepower car.
Old 06-10-2012, 06:11 PM   #10
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
Son of a bitch. So that isn't a foible, it's how they're tuned from the factory!
Well that sucks.
It's hard to say why -- I can't imagine they are preserving the AT by changing the tune to make less torque.
Guys -- once you can adjust the tune, these cars should make virtually the same power. Yeah, the MT will still have better gearing, but on the track, they will suddenly be MUCH closer in performance.
May I just say "Fuck you, Toyota (or whoever is responsible for the OEM tune)."
Until we see the two tranny's running the same AFR and ignition advance, don't count the AT out of the fight just yet.
Jordo! is offline   Reply With Quote
Old 06-10-2012, 07:50 PM   #11
arghx7
Drives: car
Post data on the timing and AFR. We need to address this with specifics rather than just with generalities and secondhand information. We don't know anything about the fuel trims or knock learning.
arghx7 is offline   Reply With Quote
Old 06-10-2012, 10:34 PM   #12
Jordo!
Jordo!'s Avatar
I'd like to see specifics too, but it was clearly running rich in the other dyno thread too, so sounds like that's just the way it is.
Wonder how they got timing data? Scan tool? Timing light?
Old 06-10-2012, 11:54 PM   #13
Lonewolf
Lonewolf's Avatar
Drives: Moped
With these new dyno plots and the gear ratio spacing differences ("double overdrive on the AT") I am really having second thoughts about an auto now. Granted, I still haven't driven the car, but the weight penalty coupled with all these detrimental AT issues is starting to make me think that unless I get this car in stick (which I can't due to practical reasons) it's not worth it. I'm a sad panda right now...
Old 06-10-2012, 11:55 PM   #14
carbonBLUE
Reverse Burnouts
well that will come with time, the tuning companies dont have the access codes to the ECU just yet to start tinkering that means we cant see that type of data yet, to me seeing that tune, it just means my engines life will be longer than that of a manual car but even though we run richer we still get LOTS more fuel milage, if we run leaner, pull more timing, we will get even better fuel mileage(run leaner means less fuel ) and more power, best of bother worlds
the auto is good but it isnt the true driving experience that the car was made for(FRS AT driver, came from a manual car before the FRS)
(wont forget you)
2011 Infiniti G37x
HKS Supercharged 86 on dyno.. Brian S Forced Induction 14 01-22-2013 12:13 PM
6MT BRZ, 6AT FR-S Dyno Comparison feedbag BRZ First-Gen (2012+) — General Topics 30 06-12-2012 12:48 PM
BRZ on the dyno Symbiont BRZ Photos, Videos, Wallpapers, Gallery Forum 1 05-22-2012 01:17 PM
engine dyno! carbonBLUE Engine, Exhaust, Transmission 21 04-25-2012 08:29 PM
