Old 02-02-2015, 06:02 PM   #1
GOT FR-S
Drives: 2013 Scion FR-S (Firestorm)
Upgraded Vortech V2 Smaller pulley question (16psi??)
I appologies as this may have been covered. I was searching thru alot of miscl stuff.
A base to start (before the bash):
1.) I have upgraded Vortech V2 (good for 55,000rpm) (previosly ran 3.125" pulley)
2.) I am in the middle of building my motor 10:1 compression Forged rods and pistons with Dynosty bearings.
I would like to run a meth kit soon, however for now basing off of running pump gas Octane 94.
I want to run around 16psi boost (good to handle 20psi MAX) Is there a smaller pulley then the 2.87"?? and who sells this other then FA20club???
I believe Vortech smallest that could work is a 2.62" Any one try using this yet or know where to get???
Also any recommendations as to why to or not to run this. I am open to factual opinions. Superchargers are still all new territory to me.
Thanks!
Vortech SC. Rev Work Header, Perrin over pipe, Invidia resonated top pipe, Greddy EVO3 exhaust, Perrin Light weight crank pulley, Gofast bits lightweight waterpump & alternator pulleys, Perrin Trans & Shifter mount, MTec Shift springs. Cusco rear diff brace, 1pc Alum Drive Shaft (Drive Shaft Shop), ATC performance clutch & Flywheel, Whiteline Positive traction bushings. Grimspeed hood struts. EcuTek Tune.
GOT FR-S is offline   Reply With Quote
Old 02-02-2015, 06:55 PM   #2
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Given the belt configuration you have to use with this kit, you'll get some serious slippage if you go under 2.87. PSI shouldn't be the goal really, especially with superchargers.
Whatabouteggs is offline   Reply With Quote
Old 02-02-2015, 10:28 PM   #3
GOT FR-S
Fair enough. I am just use to TC. Just figured wouldn't hurt to up the boost with built motor. Maybe I will just run the 2.87" pulley with meth kit. I'm not looking for massive power obviously. But would like to maximize the Vortech potential.
Old 02-02-2015, 10:29 PM   #4
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Wouldn't the 2.87 get you to around 16psi? I'm using the 3.125 and get around 12psi. You get 1-2psi every size smaller, so 3.00 would get you around 14, and the 2.87 around 16psi. I'm not really sure I'm just basing the boost from my experience.
Tye300 is offline   Reply With Quote
Old 02-02-2015, 10:41 PM   #5
GOT FR-S
You could be right. I thought the 2.87" was around 14psi. There is something to do with engine rpm to crank pulley size gives you the psi given.
The Following User Says Thank You to GOT FR-S For This Useful Post:
Tye300 (02-03-2015)
Vortech on 2.87 pulley? brocktwalker Forced Induction 22 08-22-2020 07:33 PM
vortech and smaller pulleys? cjsporl1996 Forced Induction 2 03-30-2014 10:20 AM
what is power gain with smaller pulley (vortechsupercharger) 86 Legend Forced Induction 0 01-10-2014 10:22 AM
vortech smaller pulley charged86 Engine, Exhaust, Bolt-Ons 2 08-02-2013 10:02 AM
vortech pulley ft86me Forced Induction 14 06-05-2013 03:27 PM
