Old 01-30-2015, 06:41 PM   #1
misunderstood
misunderstood's Avatar
Drives: 2015 White FRS
Wheel set up
Hey guys, what is a good wheel set up for the FRS without getting any spacers? Looking to lower my car just an 1in. maybe 2 lol. Just want to close the wheel gap.
misunderstood is offline   Reply With Quote
Old 01-30-2015, 06:45 PM   #2
Wyattkb
Drives: 2014 Whiteout FRS
Welcome to the forums. Learn to search before you get flamed.
Here is your 1 time courtesy search done for you.
http://www.ft86club.com/forums/showthread.php?t=7535
Wyattkb is offline   Reply With Quote
The Following User Says Thank You to Wyattkb For This Useful Post:
Tcoat (01-30-2015)
Old 01-30-2015, 06:46 PM   #3
misunderstood
thank you sir. i am very new to these forums lol
Old 01-30-2015, 06:47 PM   #4
PBlack09
PBlack09's Avatar
Drives: 2015 Scion FR-S Firestorm
Check out the thread linked below. It's got everything you need with wheel offset, diameter, width, tire size, and whatever else.
Also, mess around with this site. You can change the numbers and get a rough visualization of what it'll look like.
http://www.frsproject.com/tire_size.php
PBlack09 is offline   Reply With Quote
Old 01-31-2015, 08:36 PM   #5
Donbrz
Drives: 2015 Brz Blue Series
Just went through process of wheels and tires for 2015 brz. Told would be a decision based on personal preferences, objectives and budget. Found numerous factors to be considered so will provide a short list to help you get started.
Stock wheels and tires are 17x7, 215/45/70 with +48 offset. Don't forget to consider bolt size and pattern (5x100) of wheel, tire pressure monitoring device ("TPMS") needs, wheel and tire weight, temperatures and conditions you will be driving in.
In a nutshell for me, I found that the optimal for warmer climate, that fit stock height and fenders (w/o modifications for coilover springs or camber), deliver high quality and reliability (at least thus far) at a reasonable price were: Enkei RPF1s, 17x9 (approx 16 lbs), 5x100, +35 offset wheels (+38 offset will rub) with Pontanza RE-11A 245/40/17.
Even with extensive research have made one rookie mistake to watch out for - Acquired new TPMS devices directly from Suburu and did not remember to have the installer pull the TPMS ID codes off the stock wheels before removed, and to record the TPMS codes for the new devices before the tires were mounted on the new wheels. Installer was unable to program and appear Suburu dealer will need to.
17x9 +35 fits like a glove on the BRZ, and the 245/40/17 have minimal impact on speed reading compared to stock, and provide wide stance with a little poke. Hope this helps you get started.
Donbrz is offline   Reply With Quote
Old 01-31-2015, 09:10 PM   #6
Buurz
Drives:
I do have coilovers (Öhlins) and they really only lower about 1-1.5in and have 17x9 +35 Weddssport TC105-N wheels with Bridgestone Potenza RE-11A 245/40R17. They fit perfectly like DonBRZ mentioned.
The wheels are 15.4 lbs each and the tires weigh 26 lbs each
Sent from my SAMSUNG-SM-G900A using Tapatalk
Buurz is offline   Reply With Quote
Old 01-31-2015, 10:47 PM   #7
Donbrz
Really like the weds TC105-N. Looked at TC105-N, but was seeking blue or gunmetal. Was not able to locate. TPMS still gray area for me. Did you need dealer to enter into computer or find way to disconnect warning light?
Old 01-31-2015, 10:55 PM   #8
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
There's a ton of info on this, the hard part is just filtering through it. I spent an hour or two every day for several weeks before I was absolutely sure of what I wanted. I'm on stock suspension (probably going to drop it an inch soon though) and I found 17x8 +45 for the front and 17x9 +45 was perfect for what I wanted. I will be making a thread to add to all the info when I get better pictures of the car but here's a couple crappy phone pics.
Amaya is offline   Reply With Quote
Old 01-31-2015, 11:07 PM   #9
Buurz
Drives:
At the time I worked at tires plus but I previously broke a tpms and still haven't replaced the sensor. But I know how to reset the system given the right tools.
Thanks, I really like the Weds myself and the Öhlins are really good as well
Old 01-31-2015, 11:36 PM   #10
Buurz
Drives:
@Donbrz also the Weds do come in like a darker silver, I think they call it gunmetal
VarrsToen Wheel Sale - $300 Credit For Wheel Services! ES1, ES2, ES3, ES6, ES7, ES8 Sonic Motor Wheels and Tires 18 02-18-2015 08:45 PM
SCCA and NASA classes for 86 platform (wheel to wheel) ddeflyer Tracking / Autocross / HPDE / Drifting 4 10-29-2014 10:08 PM
Spacers, RS-R Springs, TPMS Sensors, Wheel Locks, Wheel Caps, Supercharged Badge DAEMANO Wheels and Tires 4 07-09-2014 01:35 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
NRG Rim/Wheel LIP PROTECTOR up to 22" Wheel - Various Colors - FREE SHIPPING!!! YURparts Wheels and Tires 3 12-16-2013 09:07 PM
