Old 01-28-2015, 08:33 PM   #1
Jar
Jar's Avatar
Drives: 2014 SWP BRZ Limited
Is there a prescribed way to take apart the console exterior?
Ugh, sorry for the poor thread title.
I've got something rattling underneath this panel here:
I'd love nothing more than to take it apart and fasten whatever it is. Has anybody taken this off?
Jar is offline   Reply With Quote
Old 01-29-2015, 12:54 AM   #2
toast
Drives: 14 BSP Edelbrock BRZ
Under that panel is a small trim piece. Pull outward (toward the door) on it, it is held in place with 5 trim clips. Next, remove the trim panel around the stereo. It also pops straight out, just use a plastic panel tool so that you don't marr it.
Next is loosening the center console. Remove rubber liner where cupholder goes and take out the two screws visible. Grab bottom of leather trim piece around ebrake and yank it straight up. That gives you access to the underside of the plastic trim ring around the shifter. Using a panel tool pop that piece up, unthread shift knob and pull the trim piece over the shifter (leather will stretch over reverse lockout lever). Remove two screws exposed by shift trim removal. Final two screws are accessed by pulling rearward on the trim panel with the start button. Once you have all six screws removed you can tug backwards on the center console and it will slide back a few inches.
You now have access to the side panels. I think there is a screw up top behind the stereo surround (and maybe one down low?) After you remove those screws the panel comes out by yanking rearward.
Sounds like a lot, but I can have it out in five minutes...
toast is offline   Reply With Quote
The Following 3 Users Say Thank You to toast For This Useful Post:
8R6 (01-30-2015), Jar (01-29-2015), NWFRS (01-29-2015)
Old 01-29-2015, 01:45 AM   #3
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
NWFRS is offline   Reply With Quote
The Following User Says Thank You to NWFRS For This Useful Post:
Jar (01-29-2015)
Old 01-29-2015, 09:29 AM   #4
Jar
Jar's Avatar
Awesome. Thanks so much Toast, I'll give it a shot. If that doesn't work I'm going NWFRS' route!
The Following User Says Thank You to Jar For This Useful Post:
NWFRS (01-29-2015)
Old 01-30-2015, 05:59 PM   #5
toast
I didn't explicitly say it, but you need to remove the trim panel from step 1 on both sides of the center console even if you are just removing the driver side knee pad.
Plasti Dip Exterior? corvino26 DIY (Do-It-Yourself) Guides 89 03-19-2014 01:08 AM
Exterior Badges Wesley Cosmetic Modification (Interior/Exterior/Lighting) 11 07-01-2013 09:13 PM
BRZ interior or FRS exterior? Latiii Cosmetic Modification (Interior/Exterior/Lighting) 10 06-20-2012 11:46 PM
