Old 01-28-2015, 12:56 AM   #1
REDHEAD LOVES FRS
Drives: 2013 frs red/white leather int.
18" Rims???? Yes or no?
About to spend considerable amount of money on some ACE Red capped V12 ' s. Can't find them in Canada. Anyone else tried this rim on the car?
REDHEAD LOVES FRS is offline   Reply With Quote
Old 01-28-2015, 01:25 AM   #2
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Never heard of these wheels :p, any image? 18" fits perfectly on the FRS. You have about 8.5 inch of width anything larger than that will start causing problem.
Offset range from 35-45, you'll be good.
Goodluck finding anything in canada, if you do. You'll pay double of what it cost. I'm in Quebec, my tax is 15% LOL... so its already more expensive than MSRP and I got another 15% to pay. Ouch.
Try to check CANADA forum for more info on shops around you I think I saw for NOVA SCOTIA
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 01-30-2015, 09:56 AM   #3
cslntuee
Drives: Subaru BRZ Limited
Any suggestion for the tire size for 18X8.5 +44 wheel?
ex. 225/40/R18; 235/40/R18; 245/40/R18 and 245/35/R18.
Which should be the best match?
(I lower my car both front and rear for 15 mm and the car is for DD)
Thanks.
cslntuee is offline   Reply With Quote
Old 02-02-2015, 12:44 AM   #4
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Yes, they will all work. I believe 245/35/R18 is closest to overall stock diameter. 225 maybe be beginning to be a little stretch for a 8.5". If you live in an area with a lot of potholes I'd go with 40 profile. I think generally speaking tires in 225/40/18 are more readily available and cheaper. Tire compound and grade is more important than the difference between those sizes imo.
mit_peid is offline   Reply With Quote
The Following User Says Thank You to mit_peid For This Useful Post:
cslntuee (02-02-2015)
Can you fit 4 wheels "17"(rims) in the frs? hugosaan Scion FR-S / Toyota 86 GT86 General Forum 26 04-10-2014 07:19 PM
Anyone selling OEM 17" rims? mrauto AFRICA 5 04-04-2014 05:04 AM
Coat stock rims in a "SBC" type color jflogerzi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-12-2013 08:45 AM
Which rims have that "concave" look SkAsphalt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-15-2012 04:44 PM
16" rims? Walexis Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 01-01-2012 03:25 AM
