Old 01-24-2015, 08:31 PM   #1
torqdork
torqdork's Avatar
Drives: RV-7
FS: Carbotech Brake Pads Fr/Rr
Carbotech pads, Fr XP10's, Rr XP8's, the combination tested and recommended by Mike at Carbotech for FR-S track duty in original boxes.
Used a handful of track days, never on street, plenty of meat remaining, used with high temp copper lube. Warm up quickly enough for auto-x IMO and transform the car on a track with stable, predictable, balanced braking forces.
New were $345+shipping. Sell locally for $180 or ship USPS Priority Mail for $200.
Paypal, thanks.
http://carbotechperformance.com/pads.asp?Make=Scion
torqdork is offline
Old 01-25-2015, 01:16 AM   #2
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
Pics? Thickness? Looking for a set of dedicated track pads and would love to try these out without having to invest full price.
YouShallKnow is offline
Old 01-25-2015, 11:12 AM   #3
torqdork
torqdork's Avatar
Drives: RV-7
Will do later today.
torqdork is offline
Old 01-25-2015, 01:03 PM   #4
torqdork
torqdork's Avatar
Drives: RV-7
Fronts measured about 1/4" material left on each pad, rears about 3/8" material left on each pad. Pads were switched l/r sides of car for each track day, not sure if that evens wear or not but fr and rr pads measured the same on both sides. Brownish residue on backing plates is from high-temp copper lube applied before each use.
torqdork is offline
Old 01-25-2015, 01:28 PM   #5
YouShallKnow
Drives: Man
Fronts are 3/16, rears are 5/16.
Don't Carbotechs have rivets that appear at 2/16?
Old 01-25-2015, 01:32 PM   #6
torqdork
torqdork's Avatar
Drives: RV-7
Don't know about rivets. Other FR-S owners have driven them to the backing plates over time but don't recall them mentioning rivets and none are visible anywhere on the pads.
torqdork is offline
Old 01-25-2015, 02:51 PM   #7
torqdork
torqdork's Avatar
Drives: RV-7
Searching various forums shows new pad material roughly 11mm so fronts have about 44% remaining, rears 73% remaining.
Many drivers using them in racing applications say they run them down to the backing plates but to use a high grade brake fluid to withstand the extra heat.
torqdork is offline
Old 01-25-2015, 03:25 PM   #8
YouShallKnow
Drives: Man
Yeah, I can't see any rivets either.
How'd you like them?
Old 01-25-2015, 03:54 PM   #9
torqdork
torqdork's Avatar
Drives: RV-7
Not well suited for street use I've read but found them exceptional on track. Properly bedded in they're quiet and the ceramic dust easily rinsed off afterward leaving no corrosion behind.
Running mostly at Portland Intl. Raceway that's two long straights connected with six turns at each end, I was able to brake at least as late, usually later, with what looked and felt like more control and stability than most cars including several in twins running other pads and heavily modified compared to my nearly stock car. Most of my overtakes were a result of setting up the pass with late braking.
Running Motul 600, never encoutered any boiling, fade or soft pedal. I'd buy them again.
torqdork is offline
Old 01-25-2015, 04:09 PM   #10
YouShallKnow
Drives: Man
I'll just be using them for track days, strongly considering taking these.
What are you replacing them with?
Old 01-25-2015, 04:34 PM   #11
torqdork
torqdork's Avatar
Drives: RV-7
Car is sold. Replaced with...
torqdork is offline
Old 01-25-2015, 05:21 PM   #12
YouShallKnow
Drives: Man
lol! A plane!
Awesome.
Alright, well I think I want the pads but I can't commit to them until next week after I move. I want to keep a buffer of cash for unexpected moving expenses.
If you still have them I'll probably take em.
Old 01-25-2015, 06:16 PM   #13
torqdork
torqdork's Avatar
Drives: RV-7
*CarboTechs sold, thanks for your interest*
torqdork is offline
NEW Carbotech CT929 XP10 Front Brake Pads mark7s4 Brakes, Suspension, Chassis 3 03-06-2015 09:56 AM
FS: Carbotech XP10 brake pads WolfpackS2k Brakes, Suspension, Chassis 3 03-31-2014 03:24 PM
FS: Brake pads - Carbotech XP8 rears and OEM fronts d1stance Brakes, Suspension, Chassis 0 12-02-2013 06:20 PM
WTB: Carbotech XP8 Front Brake Pads n8dog11914 Brakes, Suspension, Chassis 0 04-17-2013 07:57 PM
