Old 01-21-2015, 04:49 PM   #1
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Wheels + Adapter help
I have a little problem with my wheels and the 20mm adapters that I have. My current set of nuts to secure the adapters are 22mm acorn style nuts, being 22mm they hit the back of my wheels (they have no pockets on the back.) My only two options are, try to find a shorter nut style, or drill deeper into the adapter so the nut dosent stick out. I have found a 12mm open acorn nut though I still think will hit my wheel. I have found a 6mm jam nut though my biggest concern with the jam is that it seems that there isent enough threads, so I fear that it could become lose. Just confused if it is safe to run this type of nut or should I stick with the acorn style.
This is the jam nut that I have found (6mm)
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 01-21-2015, 05:18 PM   #2
btoast
I don't think it would be too hard to find new nuts that fit. I run 20mm spacers up front and the nuts provided with my spacers recess into the spacer itself. In fact, the stock bolts stick out a bit past the spacer, but the nuts are recessed.
btoast is offline   Reply With Quote
Old 01-21-2015, 05:23 PM   #3
WolfsFang
Scrape Master
WolfsFang's Avatar
DashCommand + BT1 adapter Amadeus Electronics | Audio | NAV | Infotainment 5 09-09-2014 07:59 AM
Wheel Adapter for VW OEM 5x114mm wheels ongnoi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-12-2013 08:01 PM
WhereToBuy: MAF Adapter empower-auto Engine, Exhaust, Transmission 5 06-08-2013 02:09 PM
Adapter help lookchris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-09-2013 10:39 AM
