Old 01-20-2015, 08:12 PM   #1
Tromatic
What's the OFT AT A00D ROM corresponding MT ROM?
I would like to do this:
Adding the SOFT rev limit to Automatic ROMS
OFT roms already have this for manual roms
Copy the BASE TIMING B (under Ignition timing advance folder in romraider) table and the REV LIMIT FUEL CUT table under miscellaneous limits folder the from the corresponding Manual ROM into your Automatic rom for European/Aussies this would be from the A01G rom to the A01I rom.
@Wayno found that there are two versions of the soft rev limit one has -14 in the 7600 row in Base_Timing_B and the other has -0.12 in the 7600 RPM row, shiv said pick the one that suits you best. -14.88 is in stage1 tune and -0.12 is in Stage2 tunes
also note the second last ROW the RPM value on the axis is changed to 7450 RPM.
Tromatic is offline   Reply With Quote
Old 01-20-2015, 09:20 PM   #2
steve99
the equlivant would be A00C, not sure what the rpm limit is set to on autos if you have the stock rpm limit of 7400 its not going to work unless you raise your limit or make the axis value 7350
you could pick any manual rom as the tune values are all the same.
