Old 01-18-2015, 07:35 AM   #1
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
Turbo blankets - do they help?
Hey guys,
just wanted to hear your opinion on turbo blankets. Does it improve spool and power besides lowering underhood temps? Any downside?
Which one fits the AVO turbo?
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker
Flasher is offline   Reply With Quote
Old 01-18-2015, 09:30 AM   #2
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
I bought a used kit and it came with one so I don't know the difference, but I can hold the blanket after even hard driving so it definitely lowers temps. Spool and power I'm not so sure about. Downside is if you get any oil on it it's basically no longer usable since it's a fire hazard. Also the AVO is a low mounted turbo so water can get to it easier. If your turbo isn't coated and water gets on the blanket, it holds water near the turbo and with the heat and cooling cycles can accelerate rusting the turbo.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
The Following User Says Thank You to zkv476 For This Useful Post:
Flasher (01-18-2015)
Old 01-18-2015, 10:07 AM   #3
Flasher
Smartass
Flasher's Avatar
Do you know, which blanket you got with the kit?
Old 01-18-2015, 01:53 PM   #4
zkv476
zkv476's Avatar
PTP Lava blanket. Which one fits your turbo depends specifically on what turbo you have.
Old 01-18-2015, 04:58 PM   #5
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
You can get the DEI turbo blanket. I have it on my AVO kit. Link below. The T25/T28 fits along with the T3. T3 fits a bit bigger.
https://www.designengineering.com//c...rbo-shield-kit
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
The Following User Says Thank You to DesertFrs For This Useful Post:
Flasher (01-19-2015)
Old 01-19-2015, 08:31 PM   #6
Poodles
Drives: 2015 Series.Blue
Having worked on a factory turbo car that some moron removed the heat shields on... If you value anything and everything plastic and rubber that is anywhere near that turbo, you'll run a blanket.
Nothing like having to spend a grand on a wiring harness and sensors because all the connections crumbled...
The Following User Says Thank You to Poodles For This Useful Post:
DesertFrs (01-19-2015)
Old 01-20-2015, 10:40 AM   #7
mrk1
Drives: Sterling BRZ Ltd
I run a DEI Titanium on my car and love it, you can just about touch it after a hard drive. It also makes your turbo look bigger and isn't that what every guys wants.
I hear people talk about them being an oil soaked fire hazard, um if you have that much oil leaking out you have a fire hazard as it is and should fix that.
Also the DEI on my car now is actually from my old STI, it held up great over the years. I was able to just put it right on the BRZ.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
DesertFrs (01-20-2015), Sportsguy83 (01-20-2015)
Old 01-20-2015, 12:43 PM   #8
MAPerformance
Drives: Asphalt FRS
Love my PTP Lava
MAPerformance is offline   Reply With Quote
Old 01-21-2015, 12:29 PM   #9
nonicname returns
Drives: 4 wheels
How in the world would a piece of fabric give
You any power?
nonicname returns is offline   Reply With Quote
Old 01-21-2015, 12:58 PM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
You any power?
Hotter exhaust gases will have a faster flow velocity. That could lead to better scavenging, and faster spool. But I doubt the effect of insulating such a small section would actually give measureable gains.
Old 01-22-2015, 02:42 AM   #11
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
Its more about the lower intake temps than anything else. Without one (if it it located in the right spot) will heat up the intake pipe and thus the intake air.
Kuros is offline   Reply With Quote
The Following User Says Thank You to Kuros For This Useful Post:
Astroboy (09-19-2015)
Old 01-22-2015, 04:03 PM   #12
carlossanchez89
2Supras1FR-S
Drives: 13 Scion FR-S, 87 Supra
Yes they are good for FI especially on the turbo placement and heat
carlossanchez89 is offline   Reply With Quote
The Following User Says Thank You to carlossanchez89 For This Useful Post:
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
fs feeler full blown turbo kit minus turbo kingkai23 Engine, Exhaust, Bolt-Ons 10 03-11-2014 02:59 PM
Turbo Blankets? 86_ZN6 Forced Induction 12 07-31-2013 10:19 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
