Old 01-16-2015, 01:49 AM   #1
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
ECUTEK Question
Hopefully and easy quick question for you ECUTEK experts. I will be running ecutek software with my Kraftwerks SC. This is a non carb compliant system. 5 years from now I will have to do an emissions test here in Canada. With Ecutek do I have the ability to flash back to the original rom? Yes I know it will be a pain to remove the super charger, but hey do what you gotta do. Currently I have OFT so I can flash back and forth between dealer visits. Does Ecutek work the same way? For instance before I flash my SC Tune, does ecutek store my toyota rom?
Triumphrider is offline   Reply With Quote
Old 01-16-2015, 04:09 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
ECUtek has base ROMs in it's download folder for ProECU, which is the software that you use to tune/flash. It doesn't save your stock ROM but there's no real need to.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-18-2015, 03:30 PM   #3
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
Why do you need to remove your supercharger? Isn't the test an OBD test where they plug into the port? I have the Innovate Motorsports with ECUTek and I don't think I'll need to remove this before the test.
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 01-18-2015, 03:32 PM   #4
Triumphrider
I hope I don't need to remove it. Won't really know until then
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Old 01-18-2015, 03:33 PM   #5
jjkerr626
jjkerr626's Avatar
Well I hope so too because tests are done every two years after that and I certainly don't want to be putting this on and off every two years. That's not worth it.
Old 01-18-2015, 04:51 PM   #6
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
If anything yes there are stock roms provided. But if your inspection is anything like ours (in NJ) is, I could roll in with my turbo and resonator "cats" and as long as I don't have a CEL I'd pass.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
New Guy - EcuTek Question joshb86 Engine, Exhaust, Transmission 2 06-30-2014 03:02 PM
Ecutek new tuning question beforprez Software Tuning 4 05-09-2014 10:29 PM
ECUTek question ATSAaron Engine, Exhaust, Transmission 12 04-03-2014 06:37 PM
I have a question on ecutek dannyboy Software Tuning 2 10-08-2013 11:59 AM
EcuTek Datalogging Question xxscaxx Engine, Exhaust, Transmission 8 05-24-2013 12:31 AM
