Old 01-12-2015, 12:47 PM   #1
bass_114
bass_114's Avatar
Drives: wrb brz
Rear view camera install
Hey guys, just wondering if I can get a little help to know if this kit is complete and plug and play...Im having trouble getting help locally for advice or install
Ive got a canada 2013 brz sport tech so looking to use oem headunit
thanks!
http://www.ebay.ca/itm/B1077-SUBARU-...item4ad9e32198
bass_114 is offline   Reply With Quote
Old 01-12-2015, 12:53 PM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
1. Missing harness for factory head unit. You will need to find a pin and insert into the factory harness since the stock HU doesn't even have a wire that have be tapped (just empty hole for the vid-in pin at the connector)
2. Instructions are faulty, looks likeit replaces the license plate light cover? I'm sure sure where it even mounts to. Definitely not the reverse lights as those are not at the bottom rear and at the bottom of the car.
3. If it indeed replaces the license plate cover, the camera would be facing straight down. Sort of pointless?
Get the complete systems mentioned in other posts and you'll be fine.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Factory Rear View Camera Install aznatama Electronics | Audio | NAV | Infotainment 109 09-18-2016 09:59 PM
aftermarket rear view mirror camera uninstall/install shop 1slowfrs Southern California 2 10-28-2014 02:33 PM
stock brz jdm rear view camera SuperDave Electronics | Audio | NAV | Infotainment 0 04-03-2014 09:53 AM
Rear-view camera/reverse cam. What do you have? joergasm Audio/Visual, Electronics, Infotainment, NAV 0 05-24-2013 12:25 PM
be spoke w rear view camera xpicer Electronics | Audio | NAV | Infotainment 17 10-14-2012 09:26 AM
