Old 01-12-2015, 12:24 AM   #1
Zhangy
Drives: 2015 FRS
Cruise Control causes "Thud"?
I was driving 115km on high way. I was hard on cruise and held the cruise knob in the upper position for 2/3 seconds trying to get the car to 120km. 1st second no speed increase, 2nd second no speed increase then on the 3rd second “thud" ... and my car still did not increase to 120km after 3s of lever pressing. It felt as if the automatic transmission messed up or skipped a gear...
Anyone had similar experience?
Zhangy is offline   Reply With Quote
Old 01-12-2015, 12:36 AM   #2
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
Originally Posted by Zhangy View Post
I was driving 115km on high way. I turned on cruise and held the cruise knob in the upper position for a few seconds trying to get the car to 120km. Then “thud" ... anyone had similar experience?
Never had that happen before, I use cruise control al the time for boring highway driving too. What kind of thud? I'm trying to picture what it could be. Something with the electronic throttle possibly?
lukey86 is offline   Reply With Quote
Old 01-12-2015, 12:36 AM   #3
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Was it an audible thud or just a felt thud?
Strong thud or slight?
A slight thud when taking your finger off the upper position is normal.
Wise is offline   Reply With Quote
The Following User Says Thank You to Wise For This Useful Post:
Zhangy (01-12-2015)
Old 01-12-2015, 12:39 AM   #4
WesleyG
Drives: 2014 Satin White Pearl GTS auto
has it happened only once? maybe while paying attention to the cruise control you may have hit a small imperfection in the road? has happened to me before
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 01-12-2015, 12:40 AM   #5
Zhangy
Drives: 2015 FRS
moderate thud, felt as if the transmission messed up, skipped a gear or something like that
Old 01-12-2015, 12:42 AM   #6
lukey86
Built Not Bought
lukey86's Avatar
What Wise is talking about is normal. Not usually very noticable in these cars, when hard on the cruise control theres a tiny bit of engine braking just while everything settles, would'nt describe it as an audible "thud" though
Old 01-12-2015, 12:45 AM   #7
Wise
Circle Work Clerk
What speed where you going and what gear was it in?
Auto or manual?
Old 01-12-2015, 12:54 AM   #8
lukey86
Built Not Bought
lukey86's Avatar
With autos it'll sometimes go back a gear as you hit the cruise paddle, no different to normal acceleration...then it'll slide back into top gear once your off the paddle and it settles, it's possible that it's gone back a gear at about the same time as you've let go of the paddle, which is very normal. It will feel like it's skipped a gear as you described. Autos are very weird creatures under cruise control
assuming you do have an auto lol
The Following User Says Thank You to lukey86 For This Useful Post:
Zhangy (01-12-2015)
Old 01-12-2015, 12:57 AM   #9
Zhangy
Drives: 2015 FRS
yeah i do have an auto.. sometimes I feel like I have no throttle control. Maybe it's the same reason
Old 01-12-2015, 01:00 AM   #10
lukey86
Built Not Bought
lukey86's Avatar
yeah i do have an auto.. sometimes I feel like you have no throttle control. Maybe it's the same reason
Yeah, one of the reasons I got a manual. That moment when you wanna get hard on the throttle, you put your foot down and nothing lol
Old 01-13-2015, 06:18 AM   #11
chubky
chubky's Avatar
Drives: 2014 Scion FR-S Monogram
This definitely happened to me. I was in cruise control and tried to accelerate, my rpms jumped all over the place. Haven't tried using cruise control since. None of my other cars ever did this in cruise control. Seems a bit off. I'm scheduled for a maintenance check soon. I was going to ask the dealer to take a look since my cars still under warranty
chubky is offline   Reply With Quote
Old 01-13-2015, 06:58 AM   #12
Better get it checked yes! I can do my whole 2 hour commute without touching the gas pedal once when I hit the highway. Cruise is smooth and responsive as I have ever had.
Sorry just realized you are AT and I am MT so not comparing apples to apples!
Old 01-13-2015, 12:08 PM   #13
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
The only thing that I might characterize as any sort of thud is the transmission kicking down a gear or two on steeper inclines or if I resumed the cruise at a speed way below the set point. If it isn't these things, then get your car checked.
Demandred7 is offline   Reply With Quote
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 04:05 PM
Cascade Sation BWW May9th!! for "Cruise/Photo Shoot planning" BWW 5pm!!! NickFRS Northwest 18 05-09-2014 09:04 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
