Old 01-09-2015, 05:43 PM   #1
bren5279
Drives: series.blurrr
Question Intake VVTs not responding?
Getting tired of headscratching so I Remade thread with 100$ reward: http://www.ft86club.com/forums/showt...85#post2085385
bren5279 is offline   Reply With Quote
Old 01-09-2015, 08:46 PM   #2
steve99
After ecu reset or flash you will need to start car and let it idle for about a minute , no throttle. If you dont vvt is disabled.
Do you have any cel codes if ecu is in limp home mode will also likely disable vvt.
could also be issue with your tune.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Boofneenee (01-09-2015), Whatabouteggs (01-09-2015)
Old 01-09-2015, 10:38 PM   #3
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
^This. I had this happen to me, I stepped on the gas after a flash and my cams weren't moving. I thought something was majorly wrong. Did some research and reset the ECU and was relieved.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following User Says Thank You to woode For This Useful Post:
Old 01-10-2015, 12:11 AM   #4
bren5279
Ohhh ok, Yeah I think that may be it. I only gave it about 30 seconds. Anyone know EXACTLY how long it needs to be?
BUT on the other hand, the Exhaust cam targets are all 0.
Revised the OP
Old 01-10-2015, 01:07 AM   #5
steve99
What tune are you using if its a base tune just to start car it may have intake and exhaust vvt all set to zero.
a minute of idle is generally good enough ot until idle settles at 750 rpm.
Old 01-10-2015, 01:27 AM   #6
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
i agree with Steve. is this a fresh flash? did you let it warm up before you went?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 01-10-2015, 11:31 AM   #7
bren5279
First flash they worked fine, then did the new tweaked flash and they stopped working. flashed it back to the first map and they still arent working.
It wont idle at 750rpm, idles right around 1500 but I cant find any boost leaks, pressures all seem good though.
Old 01-10-2015, 12:42 PM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
The oil needs to reach over 30C and there's a few other parameters that need to be met before the AVCS systems start to work fully. The engine needs to be at idle too and vehicle speed needs to be 0.
On a cold engine the easiest way is:
Flash, idle for 1 min or so, if it's still not active drive sedately down a road for 30 secs to 1 min, stop the car and allow to idle. The exhaust cams should become active almost immediately.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-10-2015, 01:13 PM   #9
bren5279
ok tried running for 5 minutes, driving around for 5, then reflash, gave it 5 minutes, then tried, still the same thing , did the same thing
Im stumped, Delicious tuning's stumped, no idea why its doing this...
Old 01-10-2015, 01:57 PM   #10
Kodename47
Kodename47's Avatar
Drives: UK GT86
What ROM type have you flashed? I assume you're using ECUtek so are you using the same ROM/ROM ID to log the tune as it could be a mismatch that causes false/incorrect logging?
.: Stealth 86 :.
Kodename 47 DJ:
FRS not responding to throttle at all smg1138 Issues | Warranty | Recalls / TSB 12 09-04-2014 09:58 PM
Vicious Led not responding? MObrz5 Northern California 7 05-27-2014 01:52 AM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 07:06 PM
