Old 01-09-2015, 02:29 PM   #1
MQCDoc
Drives: Black Scion FR-S
Urethane side skirts + front lip
Good day Guys
i have purchased urethane sideskirts last summer including front lip and i was wondering if theres a way to install them without percing my side quarters. i know that the windshield are boltless and the silicon they are using is very good.
should i put the 3M product + anything that will handle them?
i want to avoid touching my quarters cause i use the car every winter and the holes could rust even if i put protection.
i need advise before summer 2015 is coming.
here is the product i got:
thanks
MQCDoc is offline   Reply With Quote
Old 01-10-2015, 02:51 AM   #2
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
i think you will have to drill. with all that moisture and salt that wil build up in your underbody, i think that will cause your 3m to degrade.
id recommend you drill a pilot hole, sqeeze some silicone in it, then put in your mounting screw, then some silicone over the screw heads. that should keep it pretty sealed
mrlewistan is offline   Reply With Quote
Old 01-10-2015, 07:12 AM   #3
Malt
Drives: 2015 WRX
This is exactly what I did when I mounted mine and its held up perfectly so far.
Malt is offline   Reply With Quote
STI Front Lip with CS Side Skirts? lrobinson Cosmetic Modification (Interior/Exterior/Lighting) 8 10-07-2014 02:32 PM
WTB cheap front lip / side skirts etc _frs Want-To-Buy Requests 1 08-13-2014 01:57 AM
"TRD Style" SIDE SKIRTS POLY URETHANE cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 3 08-12-2014 02:04 AM
Do front lips look okay without side skirts Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 7 08-07-2013 01:26 AM
Size of STI Side Skirts Front lip Box ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 1 11-30-2012 08:38 PM
