Old 01-08-2015, 05:14 PM   #1
autograph
autograph's Avatar
Drives: 6MT Hot Lava
Does anyone have any experience with Perrin's Positive Steering Response System?
See http://perrinperformance.com/i-13324...-fr-s-brz.html
Says it replaces the rear bushings on the front control arm. Has anyone bought / tried these? Impressions?
Any suspension-knowledgable folks want to chip in? I've been looking for more "steering response" and maybe a little more "feel"; I've searched the forums and while there have been some things on steering feel I haven't seen much on steering response. Any other suggestions would be greatly appreciated & I imagine others will be searching for threads like this one.
autograph is offline   Reply With Quote
Old 01-08-2015, 06:38 PM   #2
Model Citizen
Lacking brains
Drives: frz
personally i wouldn't use it on a dd that sees salt.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 01-08-2015, 07:31 PM   #3
Malt
Drives: 2015 WRX
Why would a product made out of billet aluminum be affected by salt?
Malt is offline   Reply With Quote
Old 01-08-2015, 07:46 PM   #4
Model Citizen
Lacking brains
Drives: frz
Does the brz psrs still use an exposed spherical bearing like some of the past ones for other cars?
The Following User Says Thank You to Model Citizen For This Useful Post:
Calum (01-14-2015)
Old 01-09-2015, 01:52 AM   #5
GT86_PRAGUE
Drives: GT86
GT86_PRAGUE is offline   Reply With Quote
Old 01-14-2015, 03:59 PM   #6
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I found that these help with the steering quite a bit from the stock setup. The increased caster really helps in the turns. With them installed, the car seems to want to really pull into the turn from the front when compared to the stock setup. I also installed these at the same time:
Perrin Front Control Arm Brace
Password:JDM Ultimate Lateral Brace
With all of this in place, the vague, wobbly feeling I got under heavy braking into a corner was pretty much gone. Still, it was not spectacular and did not seem to do as much as I had hoped. What really made all of this work spectacularly well (and as I had intended) was this brace:
Carbing Front Crossmember Brace
I had ordered it at the same time as the rest of the items, but it took over 6 weeks to arrive because it was new and had to come from Japan. [I can't find a good link to a Carbing website that shows and explains the brace, so I used this vendor's site for the link.] After installing the Carbing brace, everything came together and worked as I had intended with greatly increased steering response, at the expense of a little more NVH.
I also added these at the same time to tame the rear of the car:
Whiteline Rear Subframe Bushing Inserts
This full setup with stock shocks and springs created handling "magic" with an alignment and some front camber bolts. That is, until recently as now my stock shocks are toast and will need replacement or upgrading to keep my car handling well.
The Following User Says Thank You to Black Tire For This Useful Post:
DAEMANO (02-03-2015)
Old 01-14-2015, 05:55 PM   #7
xwd
I think this is the same as the Whiteline Anti-Lift bushings/mounts. These always worked great on pretty much any Subaru and the BRZ uses the same basic suspension design. Unfortunately if you autocross they aren't really legal for any class other than Modified since they relocate the suspension pickup points.
The Following User Says Thank You to xwd For This Useful Post:
Racecomp Engineering (01-29-2015)
Old 01-29-2015, 08:43 AM   #8
autograph
autograph's Avatar
Black Tire -- thank you a ton for your input. Especially grateful for your impressions & letting us know about the carbing brace. From what you're saying it seems the brace made the biggest impact and I may order one myself and see what that does alone before I go for the Perrin front control brace / steering response system. Sucks that your shocks are already toast! How many miles do you have on your car? Track time?
Old 01-29-2015, 10:50 AM   #9
Black Tire
Black Tire's Avatar
I have about 40,000 miles on my car. I have had 3 days on the competition track at BIR. I also have quite a few days on a much smaller and slower track, but relatively few laps there. I am an instructor, so I usually take only a few laps at a time on the shorter track. I drive quite hard when I am on the track.
I don't know how well the Carbing brace will work without the other items. I just know that it made all my other changes work as intended. I was definitely the most effective piece in that respect.
Old 01-30-2015, 10:03 PM   #10
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
I drive my car about 1 year with whiteline caster bush (anti lift kit ). and
installed perrin PSRS 2months ago.
vibration is much increased during highway crusing. ( 100~140km/h)
steering response are not much different from whiteline bush.
if you concerned about NVH, I think whiteline anti lift kit is better solution.
and both kit will give you
1. crisper turn-in
2. stronger on-center feel
Yobiwan is offline   Reply With Quote
The Following 2 Users Say Thank You to Yobiwan For This Useful Post:
Frogamazog (04-19-2015), mokinbird87 (06-08-2015)
Old 02-01-2015, 09:43 PM   #11
autograph
autograph's Avatar
@Black Tire interesting; pretty cool that you're an instructor! well we'll see. I will post my impressions once I get my hands on one to see how as an upgrade alone the carbing brace changes things.
@Yobiwan hmm you almost make it sound like the perrin steering response system is not worth it :P s the NVH increased such that you regret installing the PSRS? worth it in your opinion? thanks to both you and @dwx for mentioning the whiteline anti-lift bushings
Old 02-02-2015, 12:26 AM   #12
Yobiwan
Yobiwan's Avatar
both work great in handling aspects .
Old 02-02-2015, 01:38 AM   #13
wootwoot
Drives: FRS
I hear that a lot of guys end up removing the perrin units because of the NVH they produce. I have the Whiteline anti-dive bushings on my car. The change is positive, but very subtle. They keep NVH very low which is a plus.
Hope that helps.
wootwoot is offline   Reply With Quote
Old 02-03-2015, 01:05 PM   #14
ramiram1984
Drives: 2016 STi DGM
I have some for sale bnib.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Perrin Transmission Support & Whiteline Gearbox Positive Shift Kit jehu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 12-14-2017 03:12 PM
Whiteline positive shift kit and perrin shifter bushing review Raven604 Engine, Exhaust, Transmission 7 04-30-2015 04:10 PM
FS: Whiteline bushings KDT926 (Positive shift kit) & KDT922 (Positive traction kit) Tim_Asphalt_FRS Transmission and Driveline 3 09-26-2014 11:41 AM
Perrin Steering Rack Lockdown: Anyone Have Experience? TouchMyHonda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-20-2014 01:27 PM
My experience. Injen/Perrin Chen Northwest 10 10-20-2012 10:18 PM
