Old 01-08-2015, 03:29 PM   #1
rmbstyle
rmbstyle's Avatar
Drives: 2014 White FR-S
Toms Tail lights Install Issue
I just got my Toms Tail Lights in and im having a lot of trouble removing the relay flasher. I'm using the screwdriver to push on the tom tap of it, and pushing behind it with a lot of force, and I can't get it off. I dont want to mar up the OEM one with the screwdriver. Any one else have trouble with this?
Thanks
rmbstyle is offline   Reply With Quote
Old 01-08-2015, 03:39 PM   #2
Foobar
SLO NO MO
Foobar's Avatar
Yeah I recall that being a pain in the ass to remove. I scratched the crap out of it and my hand.
Old 01-08-2015, 03:48 PM   #3
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Pull/pry out the trim clip with the flasher relay as one piece... It will make your life ALOT easier...
Slide the new LED flasher relay into the clip and pop it back in it's place. Done!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 01-08-2015, 03:53 PM   #4
rjsf
I couldn't get it out using the method shown by the ft86speedfactory install video as well, so I just pulled downward on the relay out of frustration and it came off with the soft white plastic clip it was attached to. It was easier to remove the clip from the stock relay afterwards (not sure if I just got lucky that it didn't break, or if it really will not break since it's made of a soft plastic), then I just attached it to the tom's relay and pushed it back on the hole in the dash beam.
I hope this helps.
rjsf is offline   Reply With Quote
Old 01-08-2015, 03:54 PM   #5
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Agreed with previous post, i had to remove the whole relay clip from the metal frame.. not unclipping it as suggest in the instructions as it was pretty hard. Just pull down hard then replace and it'll go back in snug as it was.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 01-08-2015, 04:11 PM   #6
KI_ZN6
KI_ZN6's Avatar
An alternative is to unplug the connector and leave the OEM flasher attached in its factory location. Install the new flasher and zip tie it with other wiring. That would be less painful and less risk with cutting your hand trying to yank the OEM flasher that is held by a strong plastic clip (very limited space behind the dashboard). Just my 2 cents!
KI_ZN6 is offline   Reply With Quote
Old 01-08-2015, 04:28 PM   #7
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
Installing that little relay was the hardest thing to install until I realised there was a plastic clip attached to the frame.
KungFuWaffle is offline   Reply With Quote
Old 01-08-2015, 04:32 PM   #8
rmbstyle
rmbstyle's Avatar
Thanks for the quick replies everyone! I was able to remove it finally; just took some downward pull.
WTB: clear toms tail lights Red FRS Want-To-Buy Requests 2 06-15-2014 11:57 AM
Toms Tail Lights - Clarification SBRZ14 AUSTRALIA 12 04-09-2014 09:10 PM
Wanna trade toms tail lights? eSOLOR Northern California 1 03-10-2014 04:34 PM
WTT Red Colins tail lights for TOMS White0utFrs Exterior Parts (Aero, Lighting, Etc.) 1 02-27-2014 09:35 PM
TOMS TAIL LIGHTS AND OTHER 86 parts Navas012 New England 1 09-17-2013 09:43 PM
