Old 01-05-2015, 04:59 AM   #1
luckykevin
luckykevin's Avatar
Drives: 2013 Subaru BRZ Automatic
Rev always limit to 4400 when I add RR features
Hello everyone, I'm new to ecutek and my BRZ is automatic. I have a trouble, when I add RaceRom features to my stock ROM, the engine always limit rev to 4400RPM Although I did not adjust any parameters, What's wrong with my ROM?
luckykevin is offline   Reply With Quote
Old 01-05-2015, 06:17 AM   #2
steve99
is that when your car is stationary , if so its probably launce control rpm limit.
after your doing about 10kmh full rpm will return.
do you have A02G rom ??
Old 01-05-2015, 04:28 PM   #3
Circuit Motorsports
Circuit Motorsports's Avatar
Send a message via AIM to Circuit Motorsports
With a China-Spec BRZ automatic, you should be using the "O" series ROM, one of the following:
  • ZA1JA01O
  • ZA1JA02O
  • ZA1JA03O
with A03 being the most current.
This could be a launch control limit, or the ECU is in limp mode for some reason and limits RPM.
Which ROM was on the car stock, and which ROM did you flash with RR added?
- Bob
Circuit Motorsports is offline   Reply With Quote
Old 01-06-2015, 12:17 AM   #4
luckykevin
luckykevin's Avatar
Thanks for you reply!
My car rpm limit in a full throttle acceleration, any speed, and I'm not enable the launch control function.
My stock rom is ZA1JA01O.
Old 01-06-2015, 12:21 AM   #5
jflogerzi
jflogerzi's Avatar
Sounds like limp mode. Any CELs active?
Old 01-06-2015, 12:28 AM   #6
luckykevin
luckykevin's Avatar
  • ZA1JA01O
  • ZA1JA02O
  • ZA1JA03O
- Bob
Thank you for your reply!
1.My car stock ROM is ZA1JA01O, and I just add RR to this ROM.
2.The launch control is not enabled in my tune.
3.I think the ECU is in limp mode, when I change the Limiters->Rev Limit #1 to 7450/7100, the rev limit return to normal.
Old 01-06-2015, 03:48 AM   #7
luckykevin
luckykevin's Avatar
I think I found the cause of the problem. See the screenshot attached. The stock JA01O ROM Rev Limit #1 was different with other ROMs, I can't understand why they make this different ?!
Old 01-06-2015, 12:54 PM   #8
Circuit Motorsports
That would be it! Be sure to set rev limit #1 and rev limit #2 tables to the same values.
Looks like rev limit #2 was set properly, and rev limit #1 was set low for some reason. Not sure why - looks like an error in the stock ROM. I'll notify EcuTek about it.
- Bob
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
DeliciousTuning (01-07-2015)
Old 01-07-2015, 01:36 AM   #9
luckykevin
luckykevin's Avatar
- Bob
Thank you
Intel HD Graphics 4400 - What Games Can I Run??? RacerX Off-Topic Lounge [WARNING: NO POLITICS] 7 04-10-2014 12:51 PM
No Limit Motorsports jamesm User/Vendor/Sponsor Reviews, Feedback, Comments 7 10-22-2013 04:43 PM
What is this cars limit? JonnyJames Scion FR-S / Toyota 86 GT86 General Forum 49 10-16-2013 12:38 PM
Rev Limit Acid18 Scion FR-S / Toyota 86 GT86 General Forum 36 01-13-2013 05:55 PM
Dealer Limit blackfireball5 Scion FR-S / Toyota 86 GT86 General Forum 12 06-29-2012 10:25 PM
