Old 12-28-2014, 07:15 PM   #1
MichaelCorleone
Auto X setup
Hey guys. New here. I am coming from the genesis coupe platform to the FRS. wondering what successful people are running as wheel and tire and suspension setups for solo. I have been looking and have come up with a list of things i want to get started. please give me input and both positive and negative feedback.
I am looking at:
H&R Springs
Eibach Sway bars
HVT camber plates
Tomei UEL header
Invidia N1 cat back
Invidia resonated front pipe
Invidia Over pipe
Injen Intake
DC strut tower bars
Enkei Kojin 18x8.5+45/18x9.5+45
Bridgestone RE-11 235-40/265-35
Custom dyno tune
Please give me your input. I am trying to avoid coilover setups unitl i know more about the car and how to drive it.
Thank you!
MichaelCorleone is offline   Reply With Quote
Old 12-28-2014, 07:34 PM   #2
JB86'd
JB86'd's Avatar
Drives: JAWS
What is your autox history?
As far as engine/exhaust you should add a tune to that list if you want to get optimal power and a car that runs safe and smooth.
Old 12-28-2014, 07:38 PM   #3
MichaelCorleone
Plan on tune. I have been running SM the past two years in my 13 genesis coupe that was fully prepped. I can drive. I'm by far not the best, but I'm not a noob either. Planning on staying in SM (I like my competition there). So any mods go pretty much. A squared setup was preferred on my coupe because it was heavy as hell and pushed like crazy, I've been reading that a staggered setup can dial out some of the over steer in the frs. Just looking for advice from people that know first hand on all this stuff.
Old 12-28-2014, 08:10 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Alignment will fix the handling (the frs actually will understeer).
@whataboutbob has been picking up wins in SM with the innovate SC. Maybe check out his threads/posts.
whataboutbob (12-29-2014)
Old 12-28-2014, 08:16 PM   #5
knipple
Drives: 2013 Ultramarine Scion FR-S
As a word of advice, max wheel width for STX (the street touring class that the FR-S/BR-Z falls into) is 9". With the 9.5" wheel width will place you in CSP (The Street Prepared Class that the FR-S/BR-Z falls into).
Also, for STX, the front pipe has to have a Catalytic Converter. The header may be catless in STX.
Common wheel/tire setups that I have seen for STX prepped FR-S/BR-Z will be a 17 X 9" with 245/40/17 or 255/40/17 tires on all 4 corners.
knipple is offline   Reply With Quote
The Following User Says Thank You to knipple For This Useful Post:
Old 12-28-2014, 08:18 PM   #6
MichaelCorleone
So will a 18x8.5 +45 with 255/35 fit in the front?
Old 12-28-2014, 08:21 PM   #7
finch1750
finch1750's Avatar
He is running in SM. Plus, for STX you have to have one cat no more than 6" downstream of the last OEM placement, it can be in either the header or front pipe. You talk about the most logical choice but by the rules it isn't exactly correct.
Wheel directory with fitment and pictures
http://www.ft86club.com/forums/showthread.php?t=7535
Old 12-28-2014, 08:24 PM   #8
MichaelCorleone
Thank you very much
Old 12-28-2014, 08:34 PM   #9
xwd
The only mod you have listed not STX is the 9.5" wheels and keeping a cat in either the header or front pipe. I'd just stay in STX.
SM obviously the biggest change you could do is run race tires but I'm not sure you want to go that route. However, you can get better tires than the RE-11 like the Hankook RS-3, Dunlop ZII Star Spec, or BFG Rival. It would likely make a bigger difference than anything else you have listed.
Old 12-28-2014, 08:37 PM   #10
MichaelCorleone
I work for Bridgestone and get 50% off of re 11s, until they take that away I'll likely stick with them lol. How does a staggered setup do? Does it push too bad? If so I'll just run a squared setup.
Old 12-28-2014, 09:28 PM   #11
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Running on streets in SM is suicide... why would you torture yourself such. You'd be better off configuring for STX and plan an upgrade path into SM once you get a hoosier budget.
Old 12-28-2014, 09:30 PM   #12
MichaelCorleone
Believe it or not stx is suicide period. There are extremely seasoned driver's running cars that they have been dialing in for years in stx in KYSCCA. They usually run top 3 under a mod
Old 12-28-2014, 10:12 PM   #13
MichaelCorleone
out of all the springs available, which is the most suitable for auto x? reasons why?
Old 12-28-2014, 10:36 PM   #14
wparsons
wparsons's Avatar
Springs are going to class you the same as coilovers. If you're worried about gaining experience before jumping to coilovers I would REALLY suggest running it 100% stock except tires (in CS).
Have you looked at what mods really work, or are you just throwing parts at it? Staggered tires will not be your friend, and you'll probably want to ditch the sway bars. RE11's probably aren't the fastest tire for STX either. 18's are just extra weight with no benefit either. Strut bars also won't make you faster.
I would also re-think the brands on a lot of the mods you have planned, especially the intake. Many intakes don't gain much (or any) power over a better panel filter, and some run dangerous AFR's without a tune.
If you want to run in CS, just get some stick 215's or 225's for the stock wheels.
If you want to run STX, simplify your list. You'll get way more benefit by spending properly on suspension over exhaust parts and a tune.
Get QUALITY coilovers, camber plates, rear adjustable arms, 17x9's with 245's or 255's, replace whatever bushings you're allowed to and a proper alignment.
My vote is still to run it stock (minus tires) for a season to see how you want to tweak it, otherwise you don't know what you're trying to fix.
flickr
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 07:36 AM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 11:48 AM
FS:PA Enkei Evo 5 17x7 et42 225/45/17 BFG Rivals auto x setup SterlingBrz Wheels and Tires 17 09-02-2014 10:10 AM
Tokyo Auto Salon Setup Day Gallery (290+ Photos) shawrf1 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 52 01-23-2013 05:47 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
