Drives: 2013 brz,1972 skylark
engine whine
A
bro we need a vid
| The Following 2 Users Say Thank You to Koa For This Useful Post: | Tcoat (12-22-2014), Ultramaroon (12-22-2014) |
#3 | |
![]() Can you tell if the "whine" is coming from the engine or drivetrain .. ?? Does the whine vary with the engine speed ...... or the gear speed .. ?? (well, that question made sense when I first typed it ..... )humfrz |
Drives: 2014 Subaru BRZ WRB
[ame]http://youtu.be/gW6CHGpaRfw[/ame]
If it sounds like this, then you're all good. I suspect it's the sifter bushing. I installed Whiteline transmission insert, Perrin rear shifter bushing and MTEC shift spring Kit and noticed the whine. |
Drives: 2014 Pearl BRZ Limited
I love hearing gear box whine for some reason..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully | | Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns | |
While that is true, that's not why "I" like it. I just think it makes the car feel more 'racecar.' I would do those mods JUST to get that sound..
..which makes me wonder, after those mods, why is it whining? Most gear boxes that whine that loud use spur gears right? The 86 boxes have helical gears right? Someone please shed some light on this for me..
Drives: 2013 Scion FRS
Could it be a bad bearing in the transmission? As much as I like the sound too, it is not normal to be that loud. I would take it to the dealer. I'm thinking a new transmission is going to be the solution.
#9 | |
#10 |
#11 |
Also of you want to hear spur gear whine on a normal car most Hondas in reverse use a spur gear and make a cool whine lol
#12 |
| Vortech SC - Leak & Loud Whine after Track (<6k) | SonnyBRZ | Forced Induction | 37 | 05-14-2015 04:42 PM |
| Diff whine with clutch engaged + axle seepage | Laika | Issues | Warranty | Recalls / TSB | 33 | 10-11-2014 08:16 PM |
| 2013 FR-S A/T whine.... | Tromatic | Engine, Exhaust, Transmission | 6 | 01-20-2014 12:57 PM |
| AT trans whine? Anyone else? | Hardrock4445 | Engine, Exhaust, Transmission | 1 | 05-30-2013 06:46 PM |
| Turbo Whistle v. Blower Whine | SupraLove | Forced Induction | 34 | 11-21-2012 08:56 PM |
