Old 12-18-2014, 10:21 PM   #1
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Cusco zero 3s and tein monosport
Sold my rsr's, as wanting to try something inverted and with firmer springs, as I found 7kg too soft, and the v8 has added ~40-50kg over the front.
Both are locally supported and serviceable here, which I've learnt is important.
Car isn't really a daily. It's my street legal hoon car that I use on winding roads and track for drifting.
Doesn't seem to be many reviews for either. Found a review that's labelled as zero 3s, but I'm 90% sure he has the next lower model (street zero) because they hes wound them right down and they're not that low. The sports zero3s's go 60mm lower, which makes me doubt he had that model.
Manji is offline   Reply With Quote
Old 12-18-2014, 11:15 PM   #2
Mikeez
Engineering Student
Drives: Scion FR-S 2015
I read that the Zero 3G and 3X goes 75 mm bellow the zero. Is it helpful? You mean the spring rate is 40~50 kg/in?
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 12-18-2014, 11:22 PM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I don't see any ambiguity here. V8, 40-50 kgs, front. How do you get spring rates out of that? I don't recall ever seeing a spring rate give as kg/inch. That's just weird.
Old 12-18-2014, 11:25 PM   #4
Captain Snooze
Drives: Red Herring
Budget?
Old 12-19-2014, 12:28 AM   #5
Mikeez
Engineering Student
I see things.
Old 12-19-2014, 06:02 PM   #6
Manji
Manji's Avatar
Budget?
Would rather buy what is going to be the better performer.
That said, to answer your question, say $3kUS
Old 12-19-2014, 09:10 PM   #7
I'm willing to bet I'm the only one here with experience with the Zero 3X.
I guess, my question is, what exactly is your goal? Do you have a target spring rate in mind? What kind of performance goals do you have, and what tires are you currently running?
What did you think of the Balance of your RS*R? How do you want to change that?
Old 12-20-2014, 06:33 AM   #8
Manji
Manji's Avatar
The problem with the RSR Black i's, is that they were a street focused kit. It was too easy to bottom them out, both on the street and the track. I felt the rates were too soft, so I ran bigger bars. But the bigger rear bar made the car want to oversteer even with 235 star specs 3rd gear stock power. I want to run a stiffer rear spring so I can go back to the oem bar.
Another consideration, I stuffed the rear right shock coming round a 4th gear corner and hitting the strip. Took unit to local place, oh we can't rebuild this. So no I only want to go with Cusco or Tein, and rebuildable units. Both brands are both represented here.
Spring rate wise, my research and considering the extra weight of the v8, leads me to want rears about 1.25-1.3 stiffer than the front. To go back to oem rear bar, I'm thinking rear at 9. Which puts front at 7-8. I'd prob go 8. Or maybe 9 front, 10 rear. I'll prob go 8 front, 9 rear, and see how that goes. Both the monosports and zero3s can come in that config. And both can also come in 9f10r. So I can try the stiffer springs later.
I've corrected the rear roll centre as best I can. Subframe raised. I could get a tubular subframe made with roll centre correction. But its quite a bit lighter, and I dont want to take weight out of the back. I could look at getting the wisefab rear knuckles. Im just waiting on them to come back to me if they can be used with arms that aren't theirs.
Balance wise, I felt the rsr's understeered. Until I added the rear bar.
I've never used cusco's before, but a few others here have had issues with the street kits. But cusco nz sorted them out.
I had some tein street advances back when I first got the car. They were pretty average.
But for both, you can't judge them on their products at that level. We can question why they cheapen themselves at make products at that level, but clearly they need to to stay in business.
Tyres I run a whole range. My 235 starspecs are pretty much rooted. Have some 240/610-17 full slicks to use next. I realise the rates above are on the soft side for full slicks, but I'm only going to run them because I got them cheap.
The cusco zero 3s is a competition grade unit. Its the same as as the comp zero 3 (which is just the 3x without the ext res) but the 3s is just softer sprung and valved to suit. I like that. Knowing the the unit is their comp unit (albeit entry level) and it could be revalved to be a comp zero 3.
The tein aren't like this. And are more of a stand alone product line.
Hard to find reviews across any platform on either product, as both are quite new.
The teins for me are cheaper. About 25%.
I already have rose jointed arms and solid bushings everywhere. Just getting new front lca's made atm.
I wont be running camber bolts anymore. They're okay on the street. But on the track they keep coming loose every few sessions. No matter how much I tighten them. Wont need them with top hats and lca anyway.
Old 12-20-2014, 10:37 AM   #9
Give the Cusco Zero 3S or the Tein Super Racing Damper a try with 9k/10k springs. With 9k/10k, you'll have a bias toward static understeer, so you might want a mild rear bar you can adjust, and you'll still bottom out if your ride height isn't set high enough. If you're using an aero package, choose your rates based on your aero bias.
With slicks, I'd recommend perhaps 12k/14k.
Old 06-30-2015, 09:42 AM   #10
kingkenny
Drives: 2014 Toyota GT86
How is Cusco 3x coilover ? I couldn't find any review for it !!!
kingkenny is offline   Reply With Quote
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
Cusco Zero A, and Tein Flex coilover clearance!! RallySport Direct Brakes, Suspension, Chassis 8 12-27-2013 02:22 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
CSG, Tein, Rays, AP Racing, Cusco, Berk, APR CSG Mike BRZ Photos, Videos, Wallpapers, Gallery Forum 7 07-03-2013 06:32 PM
Whiteline|Cusco|TEIN|Perrin|KW & More! All your suspension needs here @ CMS Circuit Motorsports Brakes, Suspension, Chassis 64 12-18-2012 02:25 PM
