Old 12-15-2014, 02:08 PM   #1
PantsDants
Drives: Scion FR-S A/T, Whiteout
P&L catted header - cam timing?
So I've got some small knock that just will not go away no matter how much timing I take out at 3200 rpm, 0.6-0.7 g/rev. I'm thinking I may need to revise my cam timing in that area, as I was able to sort out the rest of the knock I was getting in other areas through retarding base timing <2 degrees.
Car has a Phantom ESC and P&L EL catted header, running OFT ESC 91 octane tune. Mechanic didn't find any exhaust leaks or anything that could be rattling around, so that's why I'm thinking it's in the tune. If anyone could post up a better optimized cam timing map for a catted equal length header, I'd be very grateful. Thanks!
PantsDants is offline   Reply With Quote
Old 12-15-2014, 02:28 PM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
you sure you're using quality fuel? Try increasing octane by 1 or 2 and see if that helps, or try a different gas station?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 12-15-2014, 02:50 PM   #3
PantsDants
92 octane is the best I'm able to find in WA, and the brand of gas I use doesn't seem to have an effect either way on the knock; I don't fill up at the same gas station every time. It's also just this one very specific range that I can't seem to eliminate completely, which is why I don't think it's fuel-related.
Old 12-15-2014, 03:15 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Is it FBKC? Could it be on tip in?
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-15-2014, 03:29 PM   #5
PantsDants
It is FBKC (I think? I dunno what else it could be because it's not FLKC), but it's showing up in fairly steady state situations. Check out this log: http://datazap.me/u/pantsdants/12-13...=0&data=1-4-11
That log is with around 3.5 degrees of base timing taken out in the area, which seems like a lot, and it's still seeing knock.
Old 12-15-2014, 03:46 PM   #6
phrosty
P&L does their own tuning, have you sent them an email?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 12-15-2014, 04:42 PM   #7
steve99
Yes its FBKC or knock correction , just as you get on the throttle. @Kodename47 called it right.
On low grade fuel its very difficult to completly eliminate. your only showing -0.69 degrees max correction in that log and your iam is solid at one. With 91 fuel its going to be almost impossible to eliminate completly, but its very low level knock .
If thats as bad as it get dont worry, if it was 2 degrees and dropping your iam to less than one then you wyld be concerned.
you could try small adjustment to the tip in tables but its not something i have done so maybe someone who has altered those can advise you.
I dont think cam timing will fix this its more to do with volumetric efficiency.
Old 12-15-2014, 07:14 PM   #8
PantsDants
This is still considered tip-in knock? On two of those instances I'm actually letting off the throttle it seems, and the other one is literally less than a 1% increase in throttle position.
I hear you on this not really being a big deal. It's just bizarre that I've been able to basically get rid of all of my knock in other map regions except this one spot where it consistently crops up.
My reasoning for it being possibly related to cam timing was simply that I know header design has a big impact on how you set that up, and that the OFT map I've got was created with an uncatted, unequal length header, while I've got a catted, equal length one.
Old 12-15-2014, 07:15 PM   #9
PantsDants
I haven't tried that yet because I got the header used from a member here; I wasn't sure if I'd be entitled to their tuning info.
Old 12-15-2014, 07:55 PM   #10
steve99
I think you problem will be you have mods not catered for with the oft phantom sc tune,
even if you get info from p&l its probably not gioing to be set up for phantom sc, you best bet is probably a custom e tune from shiv as he is the one most familiar with phantom sc.
Old 12-15-2014, 11:06 PM   #11
akyp
Drives: 2012 86
Same header, similar problems (FLKC everywhere unless I dial base timing WAY back). Emailed P&L about cam timings and basically got a NO as answer. Recently been filing up with Esso instead of Shell V-Power which alleviates the problem a good bit but still I guess a dyno tune is inevitable. Running OTS Stg 2 with timing pulled at high rpms.
akyp is offline   Reply With Quote
Old 12-16-2014, 07:22 PM   #12
PantsDants
Did they say no as in they don't have the maps, or no as in they're not giving them to you?
Old 12-16-2014, 10:07 PM   #13
akyp
Drives: 2012 86
They said they don't provide that information. So they probably have it.
Btw, looked at your log at home and I wouldn't worry about it at all. Mine looks way worse: http://www.datazap.me/u/akyp/20141215-stg-2-a00g-06
Old 11-27-2015, 06:29 PM   #14
KoolBRZ
KoolBRZ's Avatar
Knock virtually eliminated with new PI to DI ratio table. Read the thread here http://www.ft86club.com/forums/showthread.php?t=71506 and copy the table from here http://www.ft86club.com/forums/showp...&postcount=112 . I have tried to tweak it in little ways to improve it, but I can't find any changes that actually improve it. I'm adding in timing and I still have a steady IAM of 1.0. @thambu19 really knows his stuff.
If I say yes, will that make you think I understand?
EL Catted Header: P&L vs JDL? Pacific Auto Engine, Exhaust, Transmission 32 03-11-2019 12:57 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
FT: P&L header catted DP for non-catted DP mtsound Engine, Exhaust, Bolt-Ons 4 12-18-2013 03:22 PM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
