Old 12-14-2014, 11:29 PM   #1
rocketbunnyfrs86
Drives: 2015 Scion Fr-s
More HP?
What can i do to make my frs faster? It only pulls 200 hp ! Cold air intake or a chip? The frs is a drift machine but i think it needs more hp!
Thanks for the help
rocketbunnyfrs86 is offline   Reply With Quote
Old 12-14-2014, 11:49 PM   #2
driftguy
driftguy's Avatar
Drives: In between cars... 2018 Ninja 1000
Obvious troll is obvious. Please go away.
driftguy is offline   Reply With Quote
Old 12-14-2014, 11:55 PM   #3
jdmblood
jdmblood's Avatar
Drives: white subaru brz
Thanks for the help
Step 1: Go to ford dealership
Step 2: Trade car in for Ford Mustang Gt
Step 3: Delete your account on ft86club
jdmblood is offline   Reply With Quote
Old 12-15-2014, 01:01 AM   #4
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Serious answer - Header + Tune + E85
Non-Serious answer - AWD Turbo LSX Swap with a Motec System Exhaust and a NOS Frogger System.
Wise is offline   Reply With Quote
Old 12-15-2014, 01:05 AM   #5
funwheeldrive
NOS
Old 12-15-2014, 01:18 AM   #6
艾洛
艾洛's Avatar
Drives: Raven
These stick on vents are the best bang for the buck. DIY is simple and straightforward. Peel the tape back and slap it on under the 86 piston. You get about +100hp PER addition, this means you can get +100 hp to your rear right wheel and another +100hp to your rear left wheel if you decide to put one on each end. Be careful if you only put one on. That side will be pushing twice as much power as the other wheel.
On a more serious note, if you bought this car for HP, I think you got the wrong car. There are definitely many more cars that are better for the $ if you care for HP+Drifting.
艾洛 is offline   Reply With Quote
Old 12-15-2014, 01:19 AM   #7
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
NOS
No 2 cans of NOS overnight from japan
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 12-15-2014, 01:19 AM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Drifting what gear?
2nd, no problem.
3rd, no problem.
4th? Good luck with that.
-alex
Old 12-15-2014, 01:24 AM   #9
Obja
Obja's Avatar
Drives: Raven FRS/c5 Corvette
get out of your car and push it
Obja is offline   Reply With Quote
Old 12-15-2014, 05:55 AM   #10
BlackMonarch
Drives: Red BRZ
Lost my shit @ NOS frogger system.
BlackMonarch is offline   Reply With Quote
Old 12-15-2014, 06:35 AM   #11
AeroToy
AeroToy's Avatar
Drives: Toyota GT86 Aero 2012
There is this new thing out now, It adds 5 hp without even touching your engine!
If you decide to try this, plea let us know if this is a hoax or not! Ty.
-2012 GT86 Aero
AeroToy is offline   Reply With Quote
Old 12-15-2014, 07:59 AM   #12
Defuser
Remember
Defuser's Avatar
Drives: 2015 Asphalt
For ultimate weight reduction, remove yourself from the vehicle for best results.
This is my 17th car. Most fun so far!
Defuser is offline   Reply With Quote
Old 12-15-2014, 08:21 AM   #13
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Forget NOS bottles, you need JATO bottles!
Old 12-15-2014, 08:49 AM   #14
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
Are you running on race gas? Anything less than 110 octane and the engine limits itself to 200hp for reliability and safety reasons. I suggest buying some 114, after you burn a couple tanks of that the ecu should realize that it's race fuel and it will unlock the secret beast mode level fuel/timing maps. That'll give you about 300hp and push the torque through the roof. After using race gas for 1337 miles do the pedal dance and then start filling up with nitromethane whenever the low fuel light comes on. But don't fill it above a quarter tank or you'll be adding to much weight. Once you've achieved a minimum ratio of 88% nitromethane and 12% race gas you should see the power jump to almost 600 horses (although the technical measurements were given in MLPP or "my little ponies power", 600hp is the approximate conversion). If you are still not happy with that you'll need to add a straight through exhaust system for +60hp and a cold air intake for +90hp.
Amaya is offline   Reply With Quote
