Old 12-12-2014, 10:30 PM   #1
dejxx
dejxx's Avatar
Drives: FT-86
Best vented hood for front mounted turbo (FBM)?
I know there is a ton of info about vented hoods, but does anyone have an answer to which is the best vented hood for a front mounted turbo, in my case (near future) its for the FBM kit.
I live in a VERY hot place, so i know ill have to run with a vented hood... but there is TONS of options, and importing a hood to argentina isn't cheap, so i cant choose the wrong one.
so far ive narrowed it to:
VIS AMS style CB hood.
Seibon FA style hood
Seibon VS style
or... the super expensive S-Craft carbon fiber hood frs brz... really agressive, but tons of money.
last option would be carving the oem hood... which would be cheaper... but, dont know if it would look very good...
Help me out!!! thanks!!!
dejxx is offline   Reply With Quote
Old 12-12-2014, 10:50 PM   #2
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I've just received 2 x Seibon TS Style hoods from @ShowstoppersUSA
Being in South Africa our temps and humidity are high, so I needed to do the same and reduced engine temps.
Hood took 15 minutes to install, quality outstanding
On the functional side after install I let the car idle for 15 minutes and could feel the heat coming through the vents. I stuck pieces of paper to the vents and they were flapping around from the air flow out the vents while even idling.
Whether the hood vents work while driving, will monitor the engine temps.
Ryan86 is offline   Reply With Quote
Old 12-13-2014, 02:30 AM   #3
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
My honest opinion is that there are much better heat management methods than a vented hood. I have the vis ams hood, front mount turbo, and not much change to temps. looks good though
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 12-13-2014, 10:59 AM   #4
mike the snake
The VIS AMS hood has lots of opening area, and I think comes with removable rain guards too. That's the hood i plan to get.
There are a couple other hoods that look good too.
Old 12-13-2014, 02:14 PM   #5
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Originally Posted by rx3 View Post
You still have plenty of vents underneath the car, so the flow through the radiator may not necessarily be reduced, but in order to increase the flow through the radiator you would need vents on the hood and they should be closer to the bumper than to the windshield.
(the red areas/lines show low pressure regions.)
This is why the Seibon TS & VS Style hoods work so well, their vents are located in the high pressure zone of the hood.
Build Thread: Breaking-Bad SWP Build
OFFICIAL NM.FT86CLUB Facebook Page
mwjcyber is offline   Reply With Quote
Old 12-13-2014, 02:20 PM   #6
ModBargains.com
ModBargains.com's Avatar
There's a couple from Seibon that we carry and another style hood as well we have that would all work well, take a look:
ModBargains.com is offline   Reply With Quote
Old 12-13-2014, 09:36 PM   #7
SilverSkyline210
SilverSkyline210's Avatar
Drives: WRB BRZ
Varis ver.2 carbon hood, Im also running full blown kit, they work together awesome
SilverSkyline210 is offline   Reply With Quote
Old 12-14-2014, 08:13 AM   #8
dejxx
dejxx's Avatar
Drives: FT-86
VIS AMS hood looks very functional... removable rain guards are a must, since i travel a lot, but also track the car a couple of times a year. @SilverSkyline210 that Varis hood looks sick... big a** vents!!!! Do you track your car? notice a big difference with the hood? Cant find a price for it anywhere... not cheap i imagine...
Old 12-14-2014, 12:16 PM   #9
SilverSkyline210
Drives: WRB BRZ
The Varis hood comes with removable rain guards too , and yea i've tracked my car and it definitely keeps the car cooler, helps with daily driving too cause the A/C works alot better since it doesnt heat soak like it use to, I got mine from Bulletproof Automotive, Varis has like 4 different versions of this hood
Old 12-14-2014, 08:55 PM   #10
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
You sir have a beautiful twin! I really like the engine bay. What turbo is it?
GotBRZ1691 is offline   Reply With Quote
Old 12-15-2014, 08:02 AM   #11
SilverSkyline210
Drives: WRB BRZ
Thanks its a Garrett GT2871R, and im running full blown's stage 1 base kit
BRZ/FRS vented non-CF hood ELutz04 Cosmetic Modification (Interior/Exterior/Lighting) 2 09-29-2014 11:26 AM
Wtb vented hood/opfp ThisGuy919 Want-To-Buy Requests 3 09-28-2014 12:35 AM
WTB: Vented Hood Sportsguy83 Want-To-Buy Requests 30 03-15-2014 02:18 AM
Vented Carbon Fiber Hood for FRS and BRZ? RWDRIFT Cosmetic Modification (Interior/Exterior/Lighting) 1 07-19-2013 05:46 PM
vented hood? 75 carrera Cosmetic Modification (Interior/Exterior/Lighting) 2 07-02-2012 09:57 PM
