| Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
Drives: Splash Mountain
IPhone 6 Data draining
anyone else have this problem?
I got it end of November and got on a plan with 3 GB My data got used up quickly and a quick google search told me to turn off the Background App Refresh, which i did. Now i'm 9 days in to December and i just got a message saying i used up 75% of the data. wtf? any other suggestions? |
#2 | |
T64-416Ax3=13,140shp
Drives: 2002 AP1 and 2015 F-150 EB (DD)
yeah i have wifi at home and at work (although i just recently starting using the work one).
but when i had 2 GB with my iphone 4 i only went over 2 GB once in 2 years. so i have no idea. i turned off a bunch of the obvious data usage ones, but i'm wondering if there's something i'm missing |
Well, something isn't adding up. Unless you were streaming a lot of music/videos/etc you shouldn't be blowing through 3 gigs. My plan used to be 2 gigs and I never got close to exceeding that. Now, my 500 MB plan does suck...
#5 | |
i have no idea, i'm gonna check on it once in awhile in the nexr couple of days. no way i can burn through over 2000 MB in 9 days, especially when i'm on wifi a lot of the time |
Drives: Subaru BRZ Limited
Could be you downloaded some data in the background, like Spotify for example where they let you download a playlist for use offline.
Or you downloaded/updated your apps using cellular data. |
head of infinite swagger
Drives: 2013 FR-S 6MT
There's a huge difference between the 3G you were using before and LTE, since you're able to consume content so much more quickly you're going to be using more data.
I find that when I first get a new phone I crush my data for the first month or two while I'm trying new things and downloading new apps, then it usually goes back to normal. Anything you used before for streaming, spotify, youtube and stuff like that will use a higher quality stream since you have more bandwidth available. Same goes for things like facetime or automatic uploads of (now higher quality) pics to instagram and apps like that. Also check "automatic update" in your app store, if that's enabled it could be updating apps without you knowing over cellular.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
Drives: 2013 GBS BRZ Limited
My droid phone has a data usage app that tells you exactly what app is using what amount of data.
I would be surprised to hear the iPhone does not have a similar app. |
Granny Shifter
Drives: 2014 FR-S
iMessage and Siri both use data as well. If you're sending a bunch of pictures that may be the culprit. This is exactly why I stuck with T-Mobile. I'll deal with the spotty service as long as I never have to worry about my data usage. Not to mention I'm always around the city so coverage isn't an issue.
#10 | |
#11 | ||
#12 |
good info everyone!
thanks a lot. better to ask tech questions in here instead of the chat option for Rogers |
#13 |
Rice Monkey
Drives: 2017 Subaru BRZ Sport-Tech WRB
In most cases for me, its things like auto syncing or apps that check every few minutes (email). For me what I generally do, is turn off data unless I want to use it.
#14 |
Drives: WRB BRZ Aozora 15'
Don't recall if iPhone can do this but androids can check the data consumption of each app. That would help lots
| OFT Data log.. Are these okay | HSayaovong | Software Tuning | 2 | 03-25-2014 06:56 PM |
| K&C data | Gunman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-03-2013 01:11 PM |
| Fexible data cable to mount iphone or android in car | speedy racer | Electronics | Audio | NAV | Infotainment | 3 | 05-23-2013 09:37 AM |
| iPhone track data logger app? | Wonderbar | Tracking / Autocross / HPDE / Drifting | 14 | 05-07-2013 03:31 PM |
| Sink draining sound | kgc | Issues | Warranty | Recalls / TSB | 5 | 08-17-2012 01:06 PM |
