Drives: 2013 Asphalt FR-S/2003 Honda Accord
Winjet headlight HID fitment question
My winet headlight is being hipped and in a mean time I'm trying to get new H7 hid from eBay.
Any feedback from eBay HID?? I'm trying to get http://m.ebay.ca/itm/141387751670?_mwBanner=1 This opt7 hid kit. Would it fit to Winjet headlight?? I've personally never heard of OPT7 brand but their pricing is really good for hid kit. Thanks in advance Last edited by bhbnuckle; 12-10-2014 at 10:27 AM. |
Anybody?
Drives: 2013 FRS Whiteout
Well based on what the ebay fitment selection says, it wont fit the FRS bulb socket. The kit you're looking at is an h7 and we use an h11 for the low beam. I'm sure the winjet being made for this car will use the same bulb/socket. You may want to look at something plug and play for this car so you wont have to be crimping, splicing and or sordering wires like you'll have to with that Ebay kit. Check it Diode Dynamics for better info, they have excellent kits and have the best customer service around. Honestly speaking i would be scared to use a $33 HID kit, but thats just me.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
| The Following User Says Thank You to yomny For This Useful Post: | Diode Dynamics (03-04-2015) |
Winjet Headlight uses h7 bulb for better light output (it says on their website lol).
I'm using $40 dollars ebay HID kit for my stock headlight, and not a single problem so far. But i need to talk to Diode Dynamic vendor to get a quote first. I heard a lot of complinemt on their HID Kit. |
#5 | |
If thats the case then you're good to go, the only thing to wire is the hid bulb to the oem socket. Im no lighting pro so i dont know much about types of sockets for the different bulbs but as far as compatibilty the HID kit will match your bulb type for the headlamps, the only thing is the universal hid bulb wiring that needs to be mated to the oem bulb socket. Maybe you could use the harness Winjet uses for the h7 bulb to oem socket to connect the HID bulb to oem socket. Hopefully someone with similar modification could chime in.
| The Following User Says Thank You to yomny For This Useful Post: | bhbnuckle (12-11-2014) |
using winjet housing and ebay hid kits.
anybody with same setup? |
#7 | |
Drives: 2013 Firestorm FRS
Diode Dynamics HID kits are very well built, and have a full 3 year replacement warranty on bulbs, ballasts and relays... I have a bunch of their LED stuff on my car! |
| The Following User Says Thank You to continuecrushing For This Useful Post: | Diode Dynamics (03-04-2015) |
Drives: Whiteout FRS
Ordered DDM tuning hid kit. Will update when they come in and installed on my winjets
A Demon
Drives: Raven GT86
I have an opt 7 kit. It used to be my main bulb but had flickering issues and would only come on every once in awhile I've had to had ballast and bulbs replaced in the 6 or so months I've owned the kit.
Honestly customer service is a+++ but the product is crap. Save up some more money and buy a better kit I regret buying mine. Sent from my iPhone using Tapatalk |
#10 |
We recommend running a better quality HID kit to avoid any flickering issues or having to replace bulbs more often. A well-engineered HID kit should last you a long time (at least several years).
#11 |
Drives: '13 Whiteout FRS
I just picked up and installed a DDMTuning HID kit on my Winjets today, I went with the H7, 35w in 5000k. Install was straightforward, plug and play.
After lighting them up for the first time, the angle was extremely off but I was able to adjust it with a 8m socket like in this video: [ame="https://www.youtube.com/watch?v=hye_OnwEyTs"]Winjet FRS/BRZ Headlight Cutoff Adjustment - YouTube[/ame]. Here's a picture of the cutoff and pic of it installed. ![]() ![]() I've used DDM kits on all my cars so far, they have lifetime warranty which is convenient for me since they're local to me. Output is much brighter than the H11s on the stock headlights, but also depends on how you adjust and angle the lights. Last edited by mrxchris; 03-04-2015 at 03:52 AM. |
| The Following User Says Thank You to mrxchris For This Useful Post: | FR-STEEL (03-19-2015) |
| Fitment question | rj101592 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 09-22-2014 10:13 PM |
| fitment question | aaguilar3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 09-07-2014 08:27 PM |
| fitment question | x2board | Electronics | Audio | NAV | Infotainment | 2 | 01-26-2014 07:54 PM |
| fitment question | DanoFA20 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 02-16-2013 01:25 PM |
| Fitment question for XXR 527 | ooharloo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 07-04-2012 09:35 PM |
