Old 12-06-2014, 07:40 PM   #1
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
Backfiring tune for a daily driver
What I want to accomplish is a backfiring tune that does not rely on POL fueling or the ignition advance maps to backfire. We have all probably seen the other thread where a guy figured out that he could retard timing at low loads on the ignition advance table and run a rich afr at low loads using the primary open loop fueling table.
This results in a nice backfiring effect when the revs are dropping and you simply put the weight of your foot on the pedal. I assume that is because the throttle must be pressed at least to >0% to get the plugs sparking again. Or is it just that the fuel is completely cut when the revs are dropping? Any help or insight is appreciated. I know this is all just an effort to look cooler. lol
A side effect of the tune is that when just cruising, the load drops to .15-.2 sometimes and causes jerkiness when the load comes back up. This is the primary reason I want to avoid using the above method to get the desired pops and burbles.
Also should I worry about fouling my plugs running a temporarily extremely rich afr and retarded timing?
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 12-06-2014, 07:42 PM   #2
raven1231
Why? I don't understand the fascination. Mine does it and I find it embarassing
Old 12-06-2014, 07:48 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Diff strokes for diff folks
Old 12-06-2014, 07:53 PM   #4
BuBlake
BuBlake's Avatar
Because... and I know this is going to sound cliche... RACECAR! ha ha
Old 12-06-2014, 08:57 PM   #5
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Don't apply it over the entire rev range. When I was messing around with it I would only run from redline down to about 3500.
bee_are_zee is offline   Reply With Quote
Old 12-06-2014, 09:05 PM   #6
BuBlake
BuBlake's Avatar
That's a good way to work around, as most cruising is below 3.5k. However, I want my backfires below 3.5k! Try harder!
Old 12-06-2014, 09:19 PM   #7
bee_are_zee
Drives: GBS BRZ
I am definitely open to hear any other way to do this. My only previous idea would be to rescale the lower portion of the table to create a very small engine load range that would create the rich environment. That or determine why the table requires some kind of pedal input.
Old 12-07-2014, 04:09 AM   #8
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
you have to learn to drive around that load range to avoid the jerking but it takes practice and yes it can be annoying. easiest solution is to go ecutek and use the rom switching feature with the cruise control to run different maps
andrew5826 is offline   Reply With Quote
Old 12-07-2014, 04:22 AM   #9
Fastbrew
Drives: 2014 Pearl White BRZ
Mine does it. It also shoots flames that are visible at night. It's not all the time. It will do it when the engine is cold and I step on it a little too hard before it is all the way warmed up. Occasionally when I let off the gas at high speed.
Fastbrew is offline   Reply With Quote
Old 12-07-2014, 08:23 PM   #10
KoolBRZ
KoolBRZ's Avatar
How about just changing the table used for the "sport" button? Then it only shoots flames when you want it to, and automatically resets every time you shut the car off, so the wife doesn't accidentally drive off and get arrested for shooting flames in the mall parking lot.
Old 12-07-2014, 09:46 PM   #11
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
Anyway to do this with OFT?
904FRSlow is offline   Reply With Quote
Old 12-07-2014, 10:10 PM   #12
Teseo
Drives: frs
If you are on budget, go with ALS (Anti-Lag-System).
The backfire come with nice bang-bang
Old 12-07-2014, 10:21 PM   #13
bee_are_zee
Drives: GBS BRZ
Short answer yes, there is an entire thread about it. I have no idea how to link threads on mobile, search backfire in the tuning section
Old 12-08-2014, 07:59 PM   #14
Tenchi
Tenchi's Avatar
Drives: Silver Ignition 6MT 10 series FR-S
I ran a map on my OFT for backfires and it ruined my exhaust. I suggest that you pass on this one. Just my .02
Tenchi is offline   Reply With Quote
New to me daily driver.. 95 M3. Dave-ROR Other Vehicles & General Automotive Discussions 58 07-17-2014 02:05 AM
Is your FR-S your daily driver? Drive Scion FR-S / Toyota 86 GT86 General Forum 136 02-10-2014 09:10 AM
Tune for Daily Driver Nevermore Software Tuning 33 12-25-2013 07:58 PM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 09:50 AM
The daily driver KiingDavid CANADA 25 02-06-2012 01:14 PM
