Old 12-04-2014, 12:52 PM   #1
MTK__
Drives: 2014 FRS Monogram
Another Coilover questionaire
So i've done the forum search and can't find much information on this so i figured i could make a thread on it.
Powered by Max Comp Coils vs Tein Street Flex
I know that no two coilovers are alike but which of these two would be better for someone who wants to have a daily & auto-x. I don't really want to see the fitment or low and all of that, and i know opinion is pretty much all i'd be getting, but which would it be?
I've recently found that there's a deal for the Tein Street flexes so that is the only reason why these two are in the same bracket.
I previously ran PBMs on my previous s-chassis but i haven't seen them on the zn6 much if not at all. I don't want to make the assumption that they'd feel the same on the zn6 as they were on the 240.
So as a TL;DR, has anyone ridden on either coilover and be able to give me input on the ride feel & their reliability? (pls no "dude you can slam the crap out of it with these tho)
MTK__ is offline   Reply With Quote
Old 12-04-2014, 01:36 PM   #2
CSG David
CSG David's Avatar
You listed an inexpensive coilover vs. a decent inexpensive coilover. TEIN is superior and the ride quality is definitely better than the other listed option.
Old 12-07-2014, 03:22 PM   #3
executivekoala
executivekoala's Avatar
Drives: fr-s
^Implying Parts Shop Max is inferior....... Pbm's are stiff and have survived me crashing my rear, tack abuse and dirt drops. Shocks are fine. Zero issues only, other coil I would get over these is KW'S but if you step to the pro's you will get a better ride. I have the comps and I still think the ride is fine.
executivekoala is offline   Reply With Quote
Old 12-07-2014, 04:13 PM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by executivekoala View Post
^Implying Parts Shop Max is inferior....... Pbm's are stiff and have survived me crashing my rear, tack abuse and dirt drops. Shocks are fine. Zero issues only, other coil I would get over these is KW'S and thats because I like the color but if you step to the pro's you will get a better ride. I have the comps and I still think the ride is fine.
"Stiff" describes my old car's setup, which I knew was crap but was the best compromise I could get with available parts and budget (I invested nothing in the suspension, the car came with adjustable struts and performed best with the back full stiff... on 130lb springs!) I know nothing about the PBM's, so have no opinion here, but would be bumping them down the list if they were on mine, based on your description. Makes me curious - wish it were easy to go try everything out.
C
Old 12-07-2014, 06:50 PM   #5
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
What do you think of the ride compared to the Tein Street Flex?
Right, because the color gives an indication of the quality of the damper.
Old 12-07-2014, 07:19 PM   #6
executivekoala
Drives: fr-s
I haven't rode on teins. Its stiff and they are drift parts and its made for more stability through transitions so ride quality isn't really 1st priority. I would rather have KW'S for the level of adjustment color was a joke, but everything to me in the 1k to 1.5k range is mostly the same. PBM does stock replacement parts in the U.S. so rebuild is not a issue.
coilovers, powered by max, tein coilovers, tein street flex
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Which sub <$1,500 coilover? fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 04-01-2014 09:42 AM
ISC Coilover scionfr_s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 02-28-2014 05:43 PM
What coilover should i get ric342 Scion FR-S / Toyota 86 GT86 General Forum 3 06-18-2013 12:36 AM
Coilover Help Legacy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 05-18-2013 03:30 PM
