Old 12-03-2014, 11:48 AM   #1
wootwoot
Drives: FRS
Final drives and onboard calibrations
If you were to install an aftermarket final drive in your car, say a 4.5, what onboard measurements, if any would be thrown of? Milage? Gas milage? Anything? It seems to me that when we change the relationship between driveshaft revolutions as related to the revolutions of the wheels something will be amiss. Or am I not understanding something?
wootwoot is offline   Reply With Quote
Old 12-03-2014, 11:52 AM   #2
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Gas mileage.
Changing wheel specifications will have more of an affect on the distance traveled/revolution.
-Jack Burton
Old 12-03-2014, 11:59 AM   #3
wootwoot
Drives: FRS
Originally Posted by tahdizzle View Post
Gas mileage.
But why doesn't the final drive have the same effect as a tire swap? You are essentially putting smaller diameter tires on aren't you? By that, I mean the effect is the same so shouldn't the consequences be the same?
Old 12-03-2014, 12:07 PM   #4
tahdizzle
So elite I'm 1338
With the final drive having more teeth per inch, your engine has to spin faster to get your wheels to reach any given speed.
Your wheels are not spinning faster, your engine is. That is why it affects your gas mileage and not your speedometer.
When you change tire diameter, the speed your tires are rotating changes.
Larger diameter wheels spin slower and smaller diameter wheels spin faster, which is why they have an affect on your speedometer.
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
wootwoot (12-03-2014)
Old 12-03-2014, 12:08 PM   #5
wootwoot
Drives: FRS
Understood. You're the man.
The Following User Says Thank You to wootwoot For This Useful Post:
tahdizzle (12-03-2014)
Old 12-03-2014, 12:19 PM   #6
jvincent
jvincent's Avatar
The gear indicator might also be a little wonky since it calculated the gear you are in based on RPM and speed.
Old 12-03-2014, 12:43 PM   #7
s2d4
s2d4's Avatar
This doesn't make any sense.
Old 12-03-2014, 12:49 PM   #8
tahdizzle
So elite I'm 1338
Which part of it doesn't make sense?
The affect of increasing the teeth on the final drive?
Or the tire diameter affect on the speedometer?
-Jack Burton
Old 12-03-2014, 01:58 PM   #9
wootwoot
Drives: FRS
It is... You think open flash tablet or ecutek could fix that?
Old 12-03-2014, 01:59 PM   #10
wootwoot
Drives: FRS
I think it does...
Old 12-03-2014, 02:15 PM   #11
jvincent
jvincent's Avatar
Not sure.
Old 12-03-2014, 03:46 PM   #12
wparsons
wparsons's Avatar
Speed is determined by the wheel speed (ABS) sensors, not by the speed of the output shaft in the transmission (like lots of cars).
If the ECU uses output shaft speed to determine speed, then a final drive swap will affect speed display. Since these cars use the wheel speed sensors, it's not an issue.
Now changing tire diameter does since it's after the sensors.
As for correcting it, as far as I know it's not an option with OFT or EcuTek at this point.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 12-03-2014, 04:31 PM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I dont think it makes sense either, think about it this way, you have a latter with the rungs spaced 5 feet apart. Its going to take more work to go the distance* than if the rungs were spaced 2 feet apart. QED, the engine needs less work to move one tooth from the higher FD than from stock. This would explain why you tend to accelerate faster with a higher FD.
*song from disney's hercules which has no effect on this conversation at all
Old 12-03-2014, 04:52 PM   #14
whataboutbob
AutoX-10/10ths every run
I have a 4.556 final drive in my auto. I also have a Solo DL that can display speed using GPS measurements (I don't leave it connected to the OBDII port all the time). The speedometer in my car matches the Solo DL +/- 1MPH. YMMV.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
37 (12-04-2014), Mim (12-03-2014)
Visconti Tuning: EcuTek STG1 Pumpgas + E85 + RaceGas Calibrations Visconti Engine, Exhaust, Bolt-Ons 177 12-24-2013 01:29 AM
GT300 BRZ Onboard knoxviue BRZ Photos, Videos, Wallpapers, Gallery Forum 7 08-06-2013 10:51 AM
Drift-Office : EcuTek Calibrations Drift-Office Engine, Exhaust, Bolt-Ons 24 05-21-2013 04:33 AM
Visconti Tuning: EcuTek STG1 Pumpgas + E85 Calibrations Visconti Engine, Exhaust, Bolt-Ons 40 10-26-2012 06:49 PM
Upcoming Shows?? Events?? Food Drives?? Toy Drives?? ESC POD Northwest 6 10-01-2012 12:56 PM
