Old 12-03-2014, 04:35 AM   #1
pr0xy
Drives: '13 WRB BRZ
Can I combine the Cosworth Midpipe with a Milltek full exhaust system?
Hi all,
Sorry for the noob question. I'm not into this whole exhaust topic very well but I'm planning to set up a proper combination for my car.
As the Swiss regulations on noise are quite strict and running catless is not an option, I want to combine some high quality parts.
Now since the Milltek resonated exhaust system is matching regulations in Switzerland, I wanted to stick with this system, also because I'm thinking about going FI sooner or later, for which the exhaust system can be used again.
For the time being NA, I want to get the FT86 UEL Catted Header in combination with the catted Midpipe from Cosworth and the Milltek Exhaust System.
Will these match in length and size? Or will I have to cut some of the parts to make them match?
As I understand this picture of a Milltek, the midpipe will be the pipe that is connected on the left with the cat built in:
Could someone confirm? Thank you!
pr0xy is offline   Reply With Quote
Old 12-03-2014, 07:10 AM   #2
elBarto
elBarto's Avatar
Drives: Toyota GT86
I think you mean the frontpipe instead of the midpipe
Normally it should fit, the Milltek bolts up on OEM locations.
And as far as I know the Cosworth also.
Also that isn't a cat in the pipe on the left, it's a resonator.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 12-03-2014, 08:39 AM   #3
pr0xy
Drives: '13 WRB BRZ
Now that's an informative picture. Thank you!
From the Cosworth FAQs:
"The Cosworth front pipe/overpipe replaces 2 stock pieces - stock centre pipe and stock over pipe.
Source: http://www.cosworth.com/products/pow...ked-questions/
And the Milltek seems to be "only" Midpipe and Muffler then.
Thank you!
Milltek Exhaust system drifter Engine, Exhaust, Transmission 255 01-04-2016 04:58 AM
FS: Milltek Full Exhaust System, Resonated - San Jose, CA cpnslow Engine, Exhaust, Bolt-Ons 4 11-12-2014 02:26 AM
MY GT86 with new Milltek exhaust system FabioGT86 Engine, Exhaust, Transmission 6 10-21-2014 04:02 AM
Milltek Sport Full Exhaust System, Resonated cpnslow Engine, Exhaust, Transmission 8 08-08-2014 04:31 PM
Borla UEL Header, Full Catless exhaust, Stock Midpipe, Berk Muffler Delete evilconcarne999 Engine, Exhaust, Transmission 34 03-24-2014 01:39 PM
