Old 12-01-2014, 11:07 AM   #1
philooo
Drives: 13' Scion FRS Track car
GT86 German Cup series - documents
I was looking for roll cage build form factory and I stumbled upon some very interesting document about the German GT86 cup series.
Unfortunately they are in German, but they have a VERY VERY precise documentation of the car modifications. it is loaded with small mods.
Considering the series is backed by the manufacturer I would assume they have very good source for what needs to be modified or not.
I hope someone here can read german and provide some feedback.
couple of cool things include some cluster mod offering a shift light and buzzer.. I assume it comes with the ECU change, but would be cool to have
philooo is offline   Reply With Quote
The Following User Says Thank You to philooo For This Useful Post:
Pat (12-03-2014)
Old 12-01-2014, 11:14 AM   #2
CSG David
CSG David's Avatar
Some preliminary notes:
- Very soft springs. Seems like a very conservative setup, but Ohlins have external reservoirs...looks like a 2-way TTX setup with super beefy camber plate.
(EDIT: Rechecked specs and actually the spring setup is very similar to our setup, but stiffer (13k/16k) due to the type of tires they're using)
- Small oil cooler using a high quality core
- Motor is untouched
- Warns that Torsen LSD must be used (I'm just guessing) which means Clutch-Type LSD would be a cheater mod...
- Differential housing is enlarged for more oil capacity + includes a cooler
- Dual exhaust exhaust with high flow cats welded at the tip
- Lists two different FD. I think one uses STD Torsen LSD from the factory and the other uses an upgraded Torsen unit.
- Monster TMG strut tower bar...
- Project Mu 999 brake pads (we love this brake pad and have some in stock if you guys are interested).
- OZ wheel 17x8 +50 must be a nice light wheel, but also shows 8" is really all you need for factory power.
- Spec dry and rain tires.
- Standard rotors w/ TMG SS lines + AP Racing 660 fluid...basically RBF660.
- Brake ducting included so this is meant for W2W racing...not quite necessary for time attack.
- Full data logger, fire suppression system, and complete roll cage.
This is a pretty sweet ride. As noted, Ohlins like softer spring setups (standard basic knowledge) and roll stiffness looks to be on the softer side.
This car looks like a 80k car...any pricing?
The Following User Says Thank You to CSG David For This Useful Post:
Pat (12-03-2014)
Old 12-01-2014, 11:18 AM   #3
Oh man... Ohlins TTX...
Old 12-01-2014, 11:35 AM   #4
philooo
I am attaching the price list
40k euro, not that bad for a clean car with toyota backing.
BTW: the roll cage design is similar to their rally car CR-V3, to the exception of the bar going into the engine compartment for the rally car.
Too bad that roll cage is not NASA/SCCA friendly because this is the only roll cage with the backing of Toyota motorsports. I was trying to find good specs on the cage but no luck so far.
Old 12-01-2014, 12:37 PM   #5
CSG David
CSG David's Avatar
Looks closer to 50k+ euros. Since it's a regulated setup, it's not bad. The parts are a bit pricey. We have developed packages if people want to go for a complete Time Attack setup straight off the bat.
Old 12-01-2014, 12:40 PM   #6
Any specs on the sways? I'm guessing typical european soft spring stiff sway...
Old 12-01-2014, 01:01 PM   #7
CSG David
CSG David's Avatar
Looks like 18mm front and 14mm rear sways...uber soft...and yes...we're communicating via forums...LOL
NINJA EDIT: looks like 130kg/cm front and 160kg/cm rear springs...aka 13k/16k setup which indicates something...:P
Old 12-01-2014, 02:55 PM   #8
Dat break in communication...
Old 12-01-2014, 04:45 PM   #9
philooo
I don't think I have seen any amateur racing series with such a good documentation
ahhh zee germanz
CSG Mike (12-01-2014)
Old 12-03-2014, 03:47 PM   #10
phastafrican
phastafrican's Avatar
Drives: 2013 Raven Scion FR-S
That cage is not illegal by any means. In PT, you take +2 points for it because it is additional chassis stiffening. In any of the power to weight classes, it is perfectly OK. Not sure where you read that it isn't NASA friendly, but that is inaccurate. Please use accurate sources.
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T
phastafrican is offline   Reply With Quote
Old 12-03-2014, 04:30 PM   #11
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
seems kind of pointless... just extra weight hanging at the back and they wont get hot enough to work properly.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 12-03-2014, 04:45 PM   #12
CSG David
CSG David's Avatar
That's not the point...
Old 12-03-2014, 05:08 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The point is that the cats are there to meet a spec as required by the series or the German government or the EU, not to limit emissions output.
-alex
Old 12-03-2014, 06:05 PM   #14
philooo
sorry about that, my bad. I thought the horizontal harness was mandatory within the main hoop, but it is not...
oups
Entertaining German GT86 review NWFRS Scion FR-S / Toyota 86 GT86 General Forum 18 11-06-2014 07:31 PM
The German Take on the GT86..... ntron1 Scion FR-S / Toyota 86 GT86 General Forum 8 05-28-2013 04:38 PM
Subaru Graduate Program Documents Motopythons BRZ First-Gen (2012+) — General Topics 5 06-03-2012 12:09 PM
