Old 11-27-2014, 12:43 PM   #1
WallsAndFoundations
WallsAndFoundations's Avatar
Drives:
Gramlights 57fxx 18x9.5 +38 fitment
I'm gonna be going for some gram light 57fxx in 18x9.5+38 offset, I'm currently sitting on stock struts with some Enkei lowering springs. Does anyone know if these will fit fine?
Also, does anyone who own the wheels know if they're hubcentric or will I need to get hubcentric rings too? Thank you!
WallsAndFoundations is offline   Reply With Quote
Old 11-27-2014, 04:59 PM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
..Enkei makes lowering springs?
Typically 18x9.5 can be tricky to fit with just springs unless you either stretch the tire (ala a 235, 225...eww) are able to adjust chamber quite a bit (which would require supporting mods)
Old 11-27-2014, 05:14 PM   #3
gl2filmerguy
gl2filmerguy's Avatar
Drives: 2013 Ultramarine FR-S
Yes those will fit flush. And you shouldn't need rings.
gl2filmerguy is offline   Reply With Quote
Old 11-28-2014, 01:43 AM   #4
WallsAndFoundations
Drives:
Oops! Meant eibach! And I'm gonna camber it. I got camber bolts and I have some stance lcas waiting to be put in. So we're good?!
Old 11-28-2014, 01:44 AM   #5
WallsAndFoundations
Drives:
Sick! Thanks dude!
Old 11-28-2014, 10:41 AM   #6
raytrix
Drives: Series 10 FR-S
http://www.ft86club.com/forums/showthread.php?t=63626
raytrix is offline   Reply With Quote
Old 11-29-2014, 02:55 AM   #7
WallsAndFoundations
Drives:
Originally Posted by raytrix View Post
I saw that thread but I guess I didn't read it well enough! Thanks man!
Wheel Directory: Gram Lights 57FXX 18x9.5 +38 raytrix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 01-02-2019 12:49 PM
GramLights 57FXX 18x9.5 86SPEED Groupbuys 21 09-18-2015 01:23 PM
FS/IL> Gram Light 57FXX 18x9.5 +38 5x100 Black Machining finish raytrix Wheels and Tires 14 06-09-2014 09:21 PM
Gramlights 57FXX 18x9.5 +38 (Black on Black) GH05T Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 05-08-2014 07:44 PM
Ray's GramLights 57FXX Ray_32 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-18-2013 07:39 PM
