Old 11-14-2014, 11:17 AM   #1
Drakelee117
Drives: Subaru BRZ 2015
What does one set brake upgrade kit include?
This might sound like a stupid question but trust me I've been doing my research and I just can't seem to find out how many these kits I need to upgrade the entire break system? Take this for example, is it just for the brake either on rear or front and I need to buy two sets to upgrade my brakes?
Also, will the brake fit on the aftermarket wheel I plan to get? (which is konig illusion 18*8)
Drakelee117 is offline   Reply With Quote
Old 11-14-2014, 11:47 AM   #2
Kevinmp7
Kevinmp7's Avatar
Drives: 2014 Raven Scion FR-S Monogram Seri
Please specify which brake kit you are planning on getting first. Usually companies with sell two separate upgrade kits for the front and rear. I think I saw a full upgrade kit that includes both front and rears on the ft86speedfactory website.
2014 Scion FR-S Monogram}{1990 Mazda Miata Turbo}{2014 Honda CBR600RR
Kevinmp7 is offline   Reply With Quote
Old 11-14-2014, 01:44 PM   #3
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Also, why are you getting a BBK? Most users here (I'd guess 98%+) don't need one.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-14-2014, 01:47 PM   #4
Drakelee117
Right now I just just trying to get an idea of what upgrade am I doing, scanning through all the possible solutions.
Old 11-14-2014, 01:50 PM   #5
Racecomp Engineering
What are you trying to improve? Do you take your car to the track?
- Andy
Old 11-14-2014, 01:50 PM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
That wasn't really an answer. Why are you looking for an upgrade, which may be a downgrade? What problems are you trying to address? That answer will help lead you to viable solutions.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-14-2014, 01:51 PM   #7
Drakelee117
Besides I am not doing anything right now, since I plan to track my car, brake upgrades may come in handy. Again, just researching and planning.
Old 11-14-2014, 01:53 PM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Ok. Sebring? Homestead? PBIR?
How experienced are you?
You most likely will just need good pads and fluid. SS lines if you want them (although they aren't needed).
Multiple paths to go down once you need more thermal capacity, but I wouldn't even bother spending much time on it until you are at, or past, the limits of the OEM rotors.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-14-2014, 01:56 PM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Most BBK's are just the front. Most companies offer front and rear. The rear would only be needed for the following reasons:
1. The front kit is too big and is pissing off the computer/ABS, unlikely with EBFD fancy junk these cars have. (don't read that as "get the biggest kit available")
2. You want to save unsprung rotational weight, very limited benefit if you retain a parking brake as the hub is where you see the most weight savings.
3. Consumable cost, although the rear brakes wear so little on track that it would probably take a century to make up the cost of the rear kit.
4. Looks - this is a perfectly OK reason as long as you understand the other pros and cons.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-14-2014, 02:00 PM   #10
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Unless you're putting down some really serious power and tracking at a very competitive level, you will be just fine with stainless steel lines, new brake fluid, and a set of dedicated pads for the track.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 11-14-2014, 02:07 PM   #11
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
If you are tracking enough, the savings on consumables alone pays for a good BBK. You just have to pick the right stuff based on needs. So even if you don't exceed OEM thermal capacity there are still other benefits to consider, but it's more of a want than a need then
Wasn't disagreeing with you BTW, just providing another point of view.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-14-2014, 02:21 PM   #12
Shark_Bait88
Fair enough, and very true. If you're tracking weekly, or even every other week, then a BBK could make a lot of sense.
I was just basing my post off of the feeling I got from the OP's posts, that this probably is going to be a DD with the occasional track days or a season of autox.
Old 11-14-2014, 02:23 PM   #13
acro
Drives: GT-86
I get the want ,after 3 track days my rotors have had to be resurfaced twice and i have changed pads 4 times in 2 years and my mech says by the time ive finished with this set of pads my rotors will have to be changed.
BBK or not?
Oh yeah my car has the smaller JDM brakes
acro is offline   Reply With Quote
Old 11-14-2014, 02:27 PM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I suspect mostly DD based on his wheel choice, but I'm an asshole.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Best Brake Pad Upgrade? FT-86- Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-16-2014 12:49 PM
Brake upgrade if you're looking at 350hp DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 11-19-2013 01:26 AM
$98 Brake Fluid Upgrade Texas BRZ Tracking / Autocross / HPDE / Drifting 15 10-22-2012 02:50 AM
TRD Brake Upgrade Opie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-21-2012 04:10 PM
