Old 11-12-2014, 08:06 AM   #1
Yrr
Yrr's Avatar
Drives: Toyota GT86
ELM327 OBD2 adapter + Torque = no protocol found
Anyone else having problems with the ELM327 OBD2 adapter in combination with Torque?
Mounted the OBD2 thingie, connected the phone succesfully via bluetooth to the adapter.
After opening Torque it seems to be connecting and starts searching for protocols, but it keep cycling through a sequence of protocols but it never find one that works.
Tried it with or without the engine running and tried other apps, without any results.
Also tried the ELM327 adapter on a other car (VW) and there it's working instantly.
Any Ideas?
Yrr is offline   Reply With Quote
Old 11-12-2014, 08:57 AM   #2
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
I actually just got mine last week I cant recall which OBD2 I got but looks very similar but blue. At first a had trouble im trying to remember what I did to make it work haha.
rjgough95 is offline   Reply With Quote
Old 11-12-2014, 09:09 AM   #3
rjgough95
rjgough95's Avatar
Any Ideas?
I went into the settings and there was a tab that had to do with what type of device your using and then it gave a message what to do when you set it to Bluetooth and make sure you have it pushed all the way in. First time I didn't actually get down and put it in so I didn't have it all the way in.
Old 11-13-2014, 02:22 AM   #4
Yrr
Yrr's Avatar
Drives: Toyota GT86
Thanks rjgough95, apparently I didn't put in the device all the way in the connector correctly. Shame on me
Can't figure out what I did wrong before but I'm glad it's working now.
OBD2 ELM327 Bluetooth mini Ryan86 AFRICA 22 09-16-2019 01:21 AM
Bluetooth OBD2 Adapter qbzee007 AFRICA 24 07-16-2015 08:57 AM
BRZ vs. Torque App & Cheap OBDII Adapter extrashaky Issues | Warranty | Recalls / TSB 10 04-29-2014 03:59 PM
ELM327 Mini Bluetooth OBD2 Adapter ducks Audio/Visual, Electronics, Infotainment, NAV 1 02-22-2014 06:46 PM
OBD2 Bluetooth Adapter Ravenlokk Engine, Exhaust, Transmission 49 09-04-2013 03:50 AM
