Old 11-08-2014, 02:31 PM   #1
BRZGM3
BRZGM3's Avatar
Drives: CBS brz limited
My turbo brz
Hey guys, I've been a member for awhile. Mostly just reading and posting once in awhile but I figured it was time to post some info about myself and my car!
21 years old currently an Enlisted Technician working on the VLS launchers for the Navy.
I've always loved cars, like im sure most everyone on here. My fist car was a 91 s13 hatch that seized up shortly after I bought it. Swapped in an sr20 and loved that car more than my right hand. I also loved STI's especially the 06-07's. But I couldn't ever ditch my love of drifting for AWD. So when I heard about the brz I knew I would have one. Once I found out there wasn't a turbo and finally test drove one I knew I'd want more power and I'd end up sinking a ton of $$ into it. So to avoid financial ruin and building a brand new car, I started surfing the web for a brz that had most everything I wanted to do to the car.
First car
So while deployed I found "the one" on this forum, and set everything up to have the car delivered the day we got back to the states.
2 hours after pulling into the pier, My car arrived.
It wasn't exactly a fairy tale there were some cosmetic issues, the tune was way off and the car barely ran.
But with the help of an awesome local tuner Ross Benton and his shop Trust Automotive in, Chesapeak,VA. We were able to rebuild the fa20club kit into a nice setup, and fix all the tuning issues. Eventually putting down 406whp/323wtq on 17psi with E-80.
Shortly after that, we had some flooding and the car sucked up some water, which ended up bending a rod.
That's when we decided to rebuild the motor with forged internals. Pauter rods, acl bearings, JE low comp pistons, and the heads were sent to Element Tuning of MD for their "Big Valve Head" package.
We're currently waiting for the parts to arrive to get my baby back on the road, hopefully before Thanksgiving.
UPDATE** The car made 520whp/402wtq on 27psi here in Portland at Performance Race Engineering
On to the parts list:
PTE 5858 turbo kit remade by Trust Automotive
ID 1000cc injectors
Twin pump AEM320lph custom return fuel setup from PRE
Tial wastegate and BOV
4 bar map sensor
Mishimoto catch can
4-port boost solenoid
Perrin crank pulley
Moto-East flex fuel kit
Fullblown Radiator
Custom oil cooler from PSI
Nameless 3" resonated catback
JDL 3" Over pipe/ Front pipe
Password JDM engine dress-up kit
Spencer Fabrication front strut tower bar
Spencer Fab front crash beam
Nameless pulley covers
Futura 4 piston front brake BBK
DSS 600 hp axles
Act 6 puck clutch and lightweight flywheel
Kartboy short shifter, and shifter bushing
Mtec shift springs
oem subaru rear diffuser
Tom's USDM spec tail lights
Yellow lamix fogs
Perrin shorty antenna
Miro TE37reps 18x9.5 all around custom powder coated laser copper
Bridgestone Potenza S04-Pole Position 265 35 18 rear
Hankook Ventus V12Evo 235 40 18 front
Kics r40 neochrome lug nuts
Rolled and pulled fenders
Arc audio black series speakers all the way around the inside
Alpine type S 12" sub in the trunk
Alpine PDX amp powering everything
Stance coilovers
Stance LCA's
Megan toe arms
Perrin sway bar
Carsmo Armrest
Weather tech floor mats
JPM alcantara gauge hood
JPM alcantara one piece dash bezel
JMP alcantara Knee pads
LED interior lights
P3-Cars gauge
Aem wide band A/F and boost gauge with dash vent mount.
BRZGM3 is offline   Reply With Quote
Old 11-08-2014, 02:33 PM   #2
BRZGM3
BRZGM3's Avatar
Well its been way to long since I've updated this!
The car has seen some changes and finally has a finished tune.
The wheels were re-coated and are now lazer copper.
The 60 trim was taken out and we put in a pte5858.
Added a spencer fab front crash bar
Had a custom oil cooler put together by PSI here in Portland, OR
Then PRE here in Portland, OR did a return fuel system and a final tune.
The car made 520whp/402wtq at 27psi on E-80
Old 11-08-2014, 04:31 PM   #3
Khánh
Khánh's Avatar
Drives: sc00ter
looks nice. good luck with the build!!
Khánh is offline   Reply With Quote
Old 11-08-2014, 05:45 PM   #4
CoopBRZ
Drives: 2014 WRB BRZ
Beautiful car and nice numbers. What kinda brand/quality are those replicas TE's?
CoopBRZ is offline   Reply With Quote
Old 11-08-2014, 05:58 PM   #5
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Very clean.
AVodka14 is offline   Reply With Quote
Old 11-08-2014, 09:02 PM   #6
BRZGM3
BRZGM3's Avatar
Thanks guys, they're Miro. So far no issues with them from daily use.
Old 11-09-2014, 07:17 PM   #7
mike the snake
Very nice.
When you get to installing the FB radiator, I'd suggest getting the shroud and Spal fans as well-great package.
Also, you can move the radiator forward quite a bit by drilling new lower mounting holes forward of the stock positions, and with custom upper mounting tabs.
This gives you extra clearance and helps things run cooler.
Old 11-09-2014, 07:47 PM   #8
BRZGM3
BRZGM3's Avatar
Thanks for the tip, I actually installed the FB radiator back in May. I used the stock shroud / fans .
Old 11-09-2014, 08:16 PM   #9
Lonewolf
Lonewolf's Avatar
Drives: Moped
I'm anxious to see her up and running again...looks like it should pull nicely
Thank you again for your service
Old 11-09-2014, 08:19 PM   #10
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Can't wait for this!
slicktop is offline   Reply With Quote
Old 11-09-2014, 09:43 PM   #11
BRZGM3
BRZGM3's Avatar
Same, she's been under the knife for 2 months so anxious is an understatement lol.
When the car was running 406whp, it was a blast. Honestly, way more power than this car needs lol. But im hoping for low 500whp.
Old 11-09-2014, 09:48 PM   #12
BRZGM3
BRZGM3's Avatar
Shit, im excited for your build! Should definitely kill most every car in the area! Not to mention that sound!
Old 11-09-2014, 10:26 PM   #13
jdmblood
jdmblood's Avatar
Drives: white subaru brz
Really like the purple wheels
jdmblood is offline   Reply With Quote
Old 11-10-2014, 01:11 PM   #14
hammy
Drives:
Super clean man! Good luck with the new build!
hammy is offline   Reply With Quote
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
Greddy turbo kit and AVO world turbo kit SPECIAL PRICING! THMotorsports.com Forced Induction 129 07-24-2014 06:51 PM
Any body have a p&l turbo kit for sale or full blown turbo Anthony7515 Want-To-Buy Requests 2 06-06-2014 05:43 PM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
