Old 11-06-2014, 08:49 PM   #1
JoeMartin
Drives: 2013 Black Scion FRS
Winjets: Poor visibility?
My FR-S came with Winjets already installed and the light pattern is just horrid for night driving.
The light output itself is pretty spectacular... It's just not shining where it would be needed.
The light is WAY to the outskirts of the road. I tried using the adjuster that is hard to get to next to the fender, but it didn't seem to do anything.
Ideas?
Passenger:
Driver:
Sitting in front of garage door:
JoeMartin is offline   Reply With Quote
Old 11-07-2014, 12:38 AM   #2
Poodles
Drives: 2015 Series.Blue
Looks like aim is off and it's (probably) a crappy HID kit, so the bulbs aren't aligned either (as the winjets use H7 halogens)
Old 11-07-2014, 12:55 PM   #3
swarb
First point them lower. You can see the glare on the top half of your garage door. You could probably band-aid fix them with some eyelids. Is it a 55w kit or 35w? 55w kits are usually too bright/glare for for halogen housings.
Old 11-08-2014, 05:34 PM   #4
JoeMartin
It's a 35 watt kit. FX is the manufacturer I believe.
I'll work to lower them some when I get home tonight.
Old 11-08-2014, 06:43 PM   #5
jeffwilliams
Drives: 2014 Asphalt FRS
What bulb size are in them? When I swapped in my winjets I used the h11 hid bulbs I was using with the oem headlights. The output was pretty horrible. Got proper fitting h7 bulbs and the output is much better.
jeffwilliams is offline   Reply With Quote
Old 11-08-2014, 10:11 PM   #6
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
You're using an HID bulb in a Halogen projector.. swap back to the bulb the headlight was designed for, or swap in a proper HID projector.
Aside from that, it looks like each light is aimed out waaaaay too much, especially the passenger one.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 11-11-2014, 05:38 PM   #7
JoeMartin
How do I bring the light in more? That's one of the things I've been trying to figure out for it.
Winjets for sale ***** 21_nola_05 NY / NJ / CT / PA 8 05-27-2014 06:57 AM
PSA: Winjets for $135 leicaboss Scion FR-S / Toyota 86 GT86 General Forum 62 03-10-2014 09:14 PM
new winjets!! beaver_scott Northwest 6 02-16-2014 05:27 AM
Visibility at night during rain Bleevin CANADA 11 10-26-2012 12:53 AM
High Visibility Brake Light. ChocolateNick AUSTRALIA 8 06-27-2012 08:20 AM
