Old 06-03-2012, 11:55 PM   #1
bazguitarman
$4,900 till FR-S
bazguitarman's Avatar
Drives: 1999 Mazda Protege
Question Inexpensive, but good max performance summer tires.
Ok, I'm not ashamed to say it........I'm poor
Just buying my FR-S is going to be a stretch on my single income. Let's face it, life takes $$$'s. After rent/house payment, insurance, gas, food, utilities, soft toilet paper and the occasional date (If I'm lucky), I'll be lucky to even put tires on my FR-S. But I do plan on immediatly changing the wheels and tires when I get my car. Because the factory wheels are butt ugly and the factory tires are pretty meh.
So, I'm looking around the interwebz at tires and wheels. I've pretty much decided to go with a set of 17" x 7.5" Enkei PF01's, 45mm offset (16.8 lbs.)in bright silver for my future ultramarine FR-S. Now I just need tires.
Here are a few I'm looking at right now. As priced/speced on tirerack.com
All in 215/45/17 fitment.
1) Hankook Ventus V12 evo K110
Weight- 22 lbs.
$101.00 ea.
2) Sumitomo HTR Z III
Weight- 23 lbs.
$95.00 ea.
3) Kumho Ecsta LE Sport
Weight- 21 lbs.
$96.00 ea.
4) Continental ExtremeContact DW
Weight- 20 lbs.
$120.00 ea.
I want to keep the total cost of 4 under $500.00 without falling into the "crappy, cheap tire" grouping. These will be used for spirited road driving only. No track time. I also want to keep the weight down.
Soooo.....Help me out here. Anyone have any experience with any of these tires? Or maybe further suggestions for something better? This would probably help quite a few forum members who want an FR-S/BRZ, but don't have big bucks to buy the good stuff for them.
bazguitarman is offline   Reply With Quote
Old 06-04-2012, 12:22 AM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
your OEM tires are more than enough to keep you safe during spirited driving. Won't cost you a penny.
take it from me, ive done track days on winters
if anything, you learn control a lot better. Tires that are too sticky are generally TOO sticky for the streets, esp in an underpowered car.
Old 06-04-2012, 12:26 AM   #3
Capt Canuck
Drives: BMW E36 323is
^Definitely. You'll be more than fine on the stock set-up.
Why not try it out for 6 months and then decide whether you want to make a change
Capt Canuck is offline   Reply With Quote
Old 06-04-2012, 12:55 AM   #4
Fly Guy
Fly Guy's Avatar
Drives: '91 MR2
I'm planning to use up my OEM tires before changing them.
Tada-san: Oh so cooler than the concept.
Fly Guy is offline   Reply With Quote
Old 06-04-2012, 12:56 AM   #5
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Not to sound like an echo here but ...burn up those stockers first!!
Justin
GrimmSpeed is offline   Reply With Quote
Old 06-04-2012, 01:31 AM   #6
fatoni
If you cant afford tires, dont buy a brand new car. A used miata and some sways will get you the same pleasure plus you will save thousands. With cars I like to think that if I cant buy two, I shouldn't buy one
Old 06-04-2012, 02:20 AM   #7
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
some of us are looking for cheap tires because we will be going through them pretty quickly or need multiple sets, i know i was looking for cheap tires because i dont plan on going more than 10k miles on 1 set of tires.. lol
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 06-04-2012, 02:30 AM   #8
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I thought the factory wheels would be ugly too...but they are actually rather nice in person (still a little heavy though). If on a tight budget I would go with just changing out tires once the stockers wear down. The Kumho Ecsta LE Sport would be my choice for a great low price max performance summer tire, have a set I just recently put on my Tacoma (205/55-16 size on 16x7.5 Kosei K-1's) and love them for a daily driver tire - good dry grip levels, extremely impressive wet grip levels - going through standing water at high speed is non-issue as it cuts right through like nothing, a very quiet/subdued tone once you pass the tires grip level, and very nice transitional responsiveness while still giving a comfortably soft ride. They are more grippy than the stock Michelins and definitely have a better tread pattern with larger outside tread blocks and better circumferential grooving - hence the awesome wet handling. They are a better wet tire than the older Hankook RS-2, which was better than its replacement the RS-3. Dry grip not quite on par with the RS-2 but pretty close.
Vracer111 is offline   Reply With Quote
Old 06-04-2012, 10:05 AM   #9
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
The only tires from that list that i think are pretty good are the Ventus. I work for a tire shop and i am not fond of Extreme Contacts or Ecstas. Personally i'd go for the Dunlop Direzza Star Specs. That's my own personal preference, i'm not trying to say they stomp all other tires. However, they are good tires and they are relatively inexpensive($145 for 215/45/17) for their performance-- they just tend to get sort of greasy at high temperatures. If you're just using them for street use and Auto X i think you'd be well off.
Regarding your stock set-up, i wonder if you would consider buying new wheels & tires, then trying to sell your original wheels & tires on Craigslist. I'm expecting to see a lot of stock wheel & tire ads on craigslist from these cars.
Asterisked Accolade is offline   Reply With Quote
Old 06-04-2012, 10:20 AM   #10
blalor
Drives: WRB BRZ Limited 6MT
I race an '87 325is in the 24 Hours of LeMons. The most popular tire in the paddock by far are the Star Specs. Easily over half of the teams used 'em. They are AWESOME on the track, and we've had no problems with overheating. I run the DZ101 on my MINI and used them for track work on my now-sold E30 ('91 318is); they did get kind of greasy, so I'll probably use the Star Specs on the BRZ when the time comes.
But for now, I'm going to rock the stock tires to learn my way around this car.
blalor is offline   Reply With Quote
Old 06-04-2012, 10:36 AM   #11
Asterisked Accolade
I'm glad to hear it-- i'm going to get Enkei RPF1s and Star Specs for my Celica.
The DZ101 is just the "toned down" version of the Star Specs for the street i believe. I sell those at work. I'm glad to hear that the Star Specs did well and didn't suffer from overheating or greasiness.
Old 06-04-2012, 01:49 PM   #12
bazguitarman
$4,900 till FR-S
It's not that I can't afford tires or a new car. I make decent money, but as a single income household I have more responsibilities than just my car. I guess what I'm saying is I don't want to live for just my car. It's not my God and I don't want to worship it in exclusion of everything else.
I just want to find a decent summer tire without breaking the bank. I'll use the factory wheels and all season tires in the winter.
Looks like everyone is big on the Star Specs. A set would be $20.00 to $40.00 over my $500.00 goal, but that's no big deal. I'll be sure to check them out.
Old 06-04-2012, 01:56 PM   #13
fatoni
the added benefits of star specs far outweighs the $20setback. Just pack lunch one week out ofeach season
Old 06-04-2012, 02:00 PM   #14
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Weight- 22 lbs.
$101.00 ea.
I LOVED THESE TIRES when I had them on my Euro Accord in the UK.
Subaru STI :
Trackforged BIG summer BBQ EVAN&MONICA Northwest 3 04-18-2012 08:43 PM
What tires do you want? ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 123 12-12-2011 02:15 PM
Toyota inexpensive FR hatch to comemorate Naruse overvolting Scion FR-S / Toyota 86 GT86 General Forum 2 08-10-2010 06:27 PM
I'm afraid the FT86 might be too inexpensive. BRZrkr Scion FR-S / Toyota 86 GT86 General Forum 30 02-24-2010 02:45 PM
