Old 10-28-2014, 09:00 AM   #1
diodelphi
diodelphi's Avatar
Drives: 86
Remained fuel
any body know when fuel check light red how much fuel is in the tank?
my guess is 8litre
diodelphi is offline   Reply With Quote
Old 10-28-2014, 09:05 AM   #2
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
It's 10L as far as I can tell.
- AdrianG
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
diodelphi (10-28-2014)
Old 10-28-2014, 09:12 AM   #3
jvincent
jvincent's Avatar
Mine usually come on with about 8L left.
The Following User Says Thank You to jvincent For This Useful Post:
Old 10-28-2014, 11:00 AM   #4
diodelphi
diodelphi's Avatar
Drives: 86
it seems 6*8=48 + 2 =50
8litre above maximum pointer.
10litre after fuel red light
4*8litre between 4 section of pointer. (each section 8litre)
Old 10-28-2014, 12:09 PM   #5
wparsons
wparsons's Avatar
I've had mine come on with as little as only 38L drained from the tank, but it typically comes on around 40-42L gone (so 8-10L left in the tank, since it's 50L).
flickr
Old 10-28-2014, 12:17 PM   #6
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
It's not an exact number because of the way it works. The manual says 1.8 gal (6.8L) to be conservative and not be overconfident about remaining fuel. There's hysteresis added to the fuel light trigger otherwise it'd be blinking all the time when you accelerate at the threshold of it coming on. If you accelerate and the fuel sloshes enough that the float drops below the threshold to turn the light on, it will turn on and stay on. I've had my light come on under acceleration and when I go to fill up there would be like 3 gal (11.4L) left. If the light comes on while cruising I'll typically have only around 2 gal remaining.
zkv476 is offline   Reply With Quote
Old 10-28-2014, 03:34 PM   #7
diodelphi
diodelphi's Avatar
Drives: 86
believe 8.6 litre in tank
bore stroke 86mm 86mm
best lambda 0.86
toyota name: gt86
if brz rev limit was 8600 all numbers were around 86
SOLD, PLEASE REMOVE AZFA20 Engine, Exhaust, Bolt-Ons 11 11-15-2014 05:06 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 11:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 09:19 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 04:39 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
