Old 10-26-2014, 10:45 PM   #1
KevinTJH
Drives: Toyota GT86 RED
Best built-in Nav/GPS system in the market?
I've got the base GT 2012 model, and I wish I had waited long enough for the GTS model.
I'm looking for a new aftermarket system with a GPS, along with the stock OEM features (bluetooth, microphone, AUX, USB etc..)
What are some good compatible models I should be looking at?
Should I look for an aftermarket system or shop around for the OEM GTS system instead?
Also, would I have to mod the car in any way or is it as simple as a plug&play installation?
Thanks in advance.
KevinTJH is offline   Reply With Quote
Old 10-26-2014, 11:30 PM   #2
FrSnake
Resident Noob
FrSnake's Avatar
Drives: Satin White BRZ Limited
I have heard that the newest CA-FI one is awesome. It runs an android operating system which means you can download waze or whatever. I don't have it but I want it. Hope that helps.
USAF2013 SWP BRZ Limited- CAI, Borla Cat-Back Exhaust
“Speed has never killed anyone, suddenly becoming stationary… That’s what gets you.” -Jeremy Clarkson
FrSnake is offline   Reply With Quote
Old 10-26-2014, 11:46 PM   #3
KevinTJH
Wow, that's definitely an impressive looking unit! However, it seems a little bit excessive to me with all its features that I won't even use.
Maybe I wasn't very specific with what I wanted. I'm looking for something that looks nice but at the same time simple to navigate from one feature to the next.
Just doing a little bit of shopping online, they seem to range from about $299-$750+ on ebay (some of them even look identical but a priced differently for some reason). On local websites, some of those units range from $1000-$1799.
Are those high end units really worth the money you pay for them? I suppose the only extra feature I want from what I have is the GPS. I don't have a reverse camera nor do I need one. I wouldn't want a headunit that also takes ages to boot up.
Old 10-26-2014, 11:50 PM   #4
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
$700 is pretty mid-range/high end of mid-range as far as double-DIN head units go. If you want the best head unit with GPS, go look at the Pioneer AVIC-8000NEX. $1700 MSRP, ~$950 on Amazon. I wouldn't give anything with a resistive touch screen the time of day, much less my money.
Prog is offline   Reply With Quote
Old 10-27-2014, 12:01 AM   #5
KevinTJH
$1700 is over my budget at the moment. By "best" head unit, what improvements are you referring to? Aside from extra features (most which I won't even use), how different is a $700 unit from a $1700 unit? Better GPS reception?
I'd honestly be happy with the OEM GTS headunit, but since I'm getting something aftermarket anyway I just thought it would be nice to try something different.
Old 10-27-2014, 06:16 AM   #6
Chimera
Drives: FRS
On the pioneer brand it's the resistive vs capacitive touch screen. Capacitive is like a cell phone, resistive is more like an airport touch screen terminal. I rather like the resistive still. If you buy the 4000 nex or 5600bhs or a few other base models you can upgrade it with a GPS add on. What's nice is it looks like pioneer is using the same format between years so going that route if you want to you can upgrade again in a few years.
Old 10-27-2014, 01:32 PM   #7
tennisfreak
Drives: 2018 BMW M240i
Thanks in advance.
Any particular reasons why you dont want to use a smartphone and get a mount?
After owning multiple built in nav systems I can attest I am much happier using my smartphone and saving the $$$$.
Old 10-27-2014, 02:36 PM   #8
football751
Drives: n/a
I'm probably going to get the 4000NEX and use CarPlay and my iPhone for navigation. I'm also considering the new AppRadio 4, the screen's a bit smaller than the 4000NEX (6.2" vs 7") but it's capacitive as opposed to resistive. And it comes with a GPS antenna, so I assume it will boost your phone's GPS signal when plugged in through USB? I don't believe the AppRadio has built-in navigation.
I hate the resistive touchscreen on the built-in BRZ nav, but I like the one my Pioneer AVH has. It's much more accurate than the BRZ, so I may give the Pioneer 4000NEX a shot.
The main advantage to in-car navigation is that, depending on where you live, cell reception can be unreliable. Here in Texas there are huge areas with little to no reception so phone-based navigation is difficult.
football751 is offline   Reply With Quote
Old 10-27-2014, 02:56 PM   #9
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Get a used OEM unit w/ GPS antennae for $350.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 10-27-2014, 03:09 PM   #10
Chimera
Drives: FRS
Yea, very good and simple solution.
Old 10-27-2014, 03:17 PM   #11
football751
Drives: n/a
I agree that the actual navigation of the OEM unit is pretty good, but for me the screen is just terrible. The Pioneer unit in my other vehicle has the same type of screen (resistive) and I'd say it's 95% accurate, where I touch it once and it does what I want. The OEM BRZ screen is maybe 50% accurate; I find myself having to touch multiple times in order to get it to recognize the input.
Also if you install an OEM unit I suggest setting it up with a bypass (I think it's possible...) so the nav will work while moving. It's a royal PITA to not be able to change your route on the fly.
Old 10-27-2014, 04:23 PM   #12
tennisfreak
Oh ok. What type of phone nav you use?
I use Nokia Here nav on my phone which lets me download all of the maps to my phone so no data connection is required.
Old 10-28-2014, 01:34 AM   #13
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I have a pioneer AVH-x8500 with an add on GPS module u250. It works pretty well but part of me misses the older gps systems that does not require a 30 sec - 1 min long boot up. If you can afford it the pioneer avic-8000nex does seem like an attractive option. The 4000nex is pretty cool too with CarPlay when they get it to work. I don't know why they don't give us a highend unit with more physical buttons/volume knob, higher quality screen like a retina display (slightly smaller screen) and built in GPS. I would pay more to get that.
mit_peid is offline   Reply With Quote
Old 10-29-2014, 02:12 AM   #14
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Right, this is pretty decent -- it was also my previous system (AVH-x4500bt) -- now i am using the AVIC-8000 Nex.
FYI, I do have the u250 for sale -- as far as a headunit, find one compatible and I can sell you that u250 (shameless advertisement =P)
under 500 bucks and you'll have a decent head unit with navi =) (my navi is selling for about 250 or so).
CamryDS is offline   Reply With Quote
Anyone know of a quality 4-channel security camera system on the market? AAghassi Electronics | Audio | NAV | Infotainment 5 07-15-2014 08:06 PM
In the market BrianFRS Scion FR-S / Toyota 86 GT86 General Forum 48 05-14-2014 06:07 PM
Market value of FRS with Vortech SC reesmicm Scion FR-S / Toyota 86 GT86 General Forum 34 02-10-2014 05:32 PM
Key with after market alarm system. Mo707 Electronics | Audio | NAV | Infotainment 3 12-03-2012 09:15 PM
Be Spoke system/ BRZ system navigation swap Mrqb22 Electronics | Audio | NAV | Infotainment 4 09-27-2012 05:48 PM
