Old 10-25-2014, 01:04 PM   #1
grostoine
Drives: Subaru BRZ
Clutch for F/I car.
Hey guys. I am thinking about upgrading my kraftwerks supercharger. I am now running the stock clutch with the base kit. I wanted to get the 13psi pulley wich should bring me to +/- 300whp. Right now I have 220 lbs/ft of torque and should be close to 250 once upgrade.
I have search along the forum and people seems to experience a lot of issue with aftermarket clutches.
I wanted to have your advice on that. What clutch should I use? Can the stock clutch handle the torque that will be added?
I do not track the car and use it mostly to ride on nice days.
Thanks for your advise !
grostoine is offline   Reply With Quote
Old 10-25-2014, 06:49 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
youll find about 40 threads on this already; not sure why you needed to add to that. Exedy stage 2/ CM FX300-400/ACT. Go with one of those.
Old 10-25-2014, 07:28 PM   #3
grostoine
Drives: Subaru BRZ
I found the 40 thread you are talking about. I did not found any clear answer about clutch that should be use or not. A lot of "oh i'm having issue with the clutch" but none of the thread was actually telling the real issue.
Thanks for your advice thoo.
I heard good stuff about Bully clutch too what do you guys think about those ?
Old 10-27-2014, 08:33 AM   #4
qtwre
Drives: White FR-S
I would suggest against the Exedy Stg 2 at the moment until they can figure out what's wrong with it. There's a thread of about 10 of us right now all experiencing issues. I hope people stop throwing that suggest out there until this is resolved. We don't need to grow that list.
qtwre is offline   Reply With Quote
The Following User Says Thank You to qtwre For This Useful Post:
Sportsguy83 (10-27-2014)
Old 10-27-2014, 08:37 PM   #5
grostoine
Drives: Subaru BRZ
What is the issue about ?
Old 10-27-2014, 09:01 PM   #6
qtwre
Drives: White FR-S
The clutch is locking people out of gears. For myself at first it was stiff, then it would take a couple tries to get into gear, now I can't get it into gear from a stop without turning the car off. I won't get into my saga here, but it has been out of the car a couple times and has been thoroughly troubleshooted.
Old 10-28-2014, 02:30 AM   #7
Cal3000
Drives: Panda FR-S
I'm still on OEM clutch with ~250wtq
It is holding up well after about 15k miles with this torque level.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 10-28-2014, 02:47 AM   #8
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Would you know if this same issue affects their Stage 1 clutch as well? Or is this problem only affecting the Stg2?
Fizz is offline   Reply With Quote
Old 10-28-2014, 05:17 AM   #9
qtwre
Drives: White FR-S
I believe the stg1 is fine. At this point I'm feeling like that's the one I should have purchased.
Cal3000, I'm jealous of your hulk stock clutch. After removing my stock clutch, it actually looked fine. It wasn't burnt or abnormally worn. It looks like the pressure plate just didn't have enough clamping force. I don't imagine I was making more power than you are.
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
